Visual LISP, AutoLISP and General Customization
Change font of named Attribute through out drawing
9 REPLIES 9
Message 1 of 10
mewescott
812 Views, 9 Replies
Does anyone know how to change the font of a specific attribute in all my blocks in a drawing.  I am trying to change the INST attribute font to Arial but I have thousands of them through out my project.  My other attributes that I do not want to change are using the same Style as this block so I can not simply change the style.
9 REPLIES 9
Message 2 of 10
_Tharwat
in reply to: mewescott
AFAIK you can not change the font of the attributed block string , and changing fonts would affect on text styles in tables , anyway create a TEXT STYLE named ARIAL and try this piece of code .
(defun c:TesT (/ Unlock-layers lock-layers l lst ss n e i)
  ;; 		 Tharwat 17. Sep. 2012   			;
  ;;          Change a specific attributed ' Value style name	;
  ;;                             to ARIAL			;
  (while (setq l (tblnext "LAYER" (null l)))
    (if (eq (Logand 4 (cdr (assoc 70 l))) 4)
      (setq lst (cons (cdr (assoc 2 l)) lst))
  (defun Unlock-layers (layerlist / tbl)
    (foreach x layerlist
      (if (tblsearch "LAYER" x)
        (entmod (subst (cons 70 0) (assoc 70 (setq tbl (entget (tblobjname "LAYER" x)))) tbl))
    (command "_.regen")
  (defun lock-layers (layerlist / tbl)
        (entmod (subst (cons 70 4) (assoc 70 (setq tbl (entget (tblobjname "LAYER" x)))) tbl))
    (command "_.regen")
  (if (and (tblsearch "STYLE" "ARIAL") (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))))
    (progn (if lst
             (Unlock-layers lst)
           (repeat (setq i (sslength ss))
             (setq n (entnext (ssname ss (setq i (1- i)))))
             (while (not (eq (cdr (assoc 0 (setq e (entget n)))) "SEQEND"))
               (if (eq (cdr (assoc 1 e)) "INST")
                 (entmod (subst (cons 7 "ARIAL") (assoc 7 e) e))
               (setq n (entnext n))
             (setq n nil)
           (if lst
             (lock-layers lst)
    (princ)
  (princ)
Tharwat
Message 3 of 10
Moshe-A
in reply to: _Tharwat
Tharwat,
why BEDIT + ATTSYNC is not enough?
moshe
Message 4 of 10
mewescott
Tharwat,
Thank you, but it did not work.  It did ask to select objects but it did nothing to them.
Message 5 of 10
mewescott
in reply to: Moshe-A
Bedit with ATTSYNC would work if it was only a couple of blocks.  I may have anywhere from 20 to 50 blocks per drawing with the same INST attribute that I want to change.
Message 6 of 10
_Tharwat
Hi ,
It should work except if you do not have the attribute value INST within the selected blocks .
can you upload a sample drawing ?
Message 7 of 10
_Tharwat
You are right Moshe , but the OP have many different blocks as he/she mentioned that in post No. 5
Message 8 of 10
Moshe-A
i'm sorry i meant BATTMAN (instead of bedit+attsync)
if the problem is a text style? why don't you consider modifiy it to use the right font file
(even change it's name if needed)
moshe
Message 9 of 10
_Tharwat
moshe
You may need to re-read the first post again Moshe . Smiley Wink
The OP wants specific attribute entity with vallue and not the text style that holds them .
Message 10 of 10
mewescott
I do have multiple blocks with the same attribute name that I want to change the font on.  I have received a solution to my posting in the posting I put on the Autocad Electrical forum.  Pat Muren created a custom lisp file and script that worked like a charm.  To view the posting go to:  http://forums.autodesk.com/t5/AutoCAD-Electrical/Change-the-font-of-the-Installation-code-through-ou...
Thank you for assistance.
”Boost
