Visual LISP, AutoLISP and General Customization
Change Dynamic Block Property "Scale Uniformly" Automatically
4 REPLIES 4
jason.estas
1588 Views, 4 Replies
G'day,
Been trying to figure out how to change the Scale Uniformly property in dynamic blocks accross hundreds of drawings using either/or scripts, lisp, vba or anything else that might do the job.
WIth my limited knowledge of programming im wondering if there is someone out there that may be able to help me out?
just need to open the drawing and select the block (one block per drawing) then edit the scale uniformly property within the block, save then close the drawing and move onto the next drawing.
Thank you in advance for your help with this matter.
Jason
4 REPLIES 4
lpseifert
in reply to: jason.estas
see if this helps... no error control
(setq obj (vlax-ename->vla-object (car (entsel)))
      blknm (vlax-get obj 'Effectivename)
(vlax-for blk (vla-get-blocks
                (vla-get-ActiveDocument
                  (vlax-get-acad-object)))
  (if (eq blknm (vla-get-Name blk))
    (vlax-put blk 'BlockScaling acUniform))
~~~Civil 3D 2008~~~
msarqui
in reply to: lpseifert
Sorry for the question but: How I use it?
I tred this but I get an error when autocad starts...
(Defund c:BUS ()
pbejse
in reply to: msarqui
(Defund c:BUS ()
(Defun c:BUS ()
msarqui
in reply to: pbejse
hahaha. I guess I was tired...
Now it works fine but only one block at a time. I mean, it does not change automaticaly nested blocks. Also it does not accept "select all". I think I'll try to find another one 😞
Thanks pbejse!
”Boost
