Helo,
I need a lisp routine that changes the color of all objects in a an existant selection set MySel to NewObjectsColor
Wich is the lisp code for that?
(defun fnChangeSelColor (MySel NewObjectsColor)
Solved by Kent1Cooper. Go to Solution.
There are several ways that could be done, perhaps the simplest by way of a CHPROP command:
(command "_.chprop" MySel "" "_color" NewObjectsColor "")
Hello Kent and Thanks
Writing the following
(defun c:ddd ()
(fnChangeSelColor "PICKFIRST" 1)
I'm waiting all the users selection before calling command ddd to be set to Red.
Witch is the fault using that ?
)(defun c:ddd ()
PICKFIRST is a System Variable name, but won't do as a selection set in an AutoLISP function. Try it this way, passing the implied selection set [if there is one]:
(defun c:ddd ()
(fnChangeSelColor (ssget "_I") 1)
); defun
Read all about it in Help for the (ssget) function.
Depending on how you set up the User selection part, you might want to have it check whether there's a pre-selection:
(defun c:ddd ()
(if (ssget "I")
(fnChangeSelColor (ssget "I") 1)
); if
); defun
