change color of selection set named MySel
4 REPLIES 4
GeryKnee
601 Views, 4 Replies
Helo,
I need a lisp routine that changes the color of all objects in a an existant selection set MySel to NewObjectsColor
Wich is the lisp code for that?
(defun fnChangeSelColor (MySel NewObjectsColor)
4 REPLIES 4
Kent1Cooper
in reply to: GeryKnee
There are several ways that could be done, perhaps the simplest by way of a CHPROP command:
  (command "_.chprop" MySel "" "_color" NewObjectsColor "")
Kent Cooper, AIA
GeryKnee
in reply to: Kent1Cooper
Hello Kent and Thanks
Writing the following
(defun c:ddd ()
  (fnChangeSelColor "PICKFIRST" 1)
I'm waiting all the users selection before calling command ddd to be set to Red.
Witch is the fault using that ?
Kent1Cooper
(defun c:ddd ()
PICKFIRST is a System Variable name, but won't do as a selection set in an AutoLISP function.  Try it this way, passing the implied selection set [if there is one]:
(defun c:ddd ()
  (fnChangeSelColor (ssget "_I") 1)
); defun
Read all about it in Help for the (ssget) function.
Depending on how you set up the User selection part, you might want to have it check whether there's a pre-selection:
(defun c:ddd ()
  (if (ssget "I")
    (fnChangeSelColor (ssget "I") 1)
  ); if
); defun
Kent Cooper, AIA
GeryKnee
Thanks Kent
”Boost
