I have a Lisp that I have been working on with some folks in the office, and i feel like i am close, but i am not getting the cigar. The idea would be to have the lisp allow the user to select a nested x-ref entity, and change the color and linetype of the selected layer, similar to the old "LAP" command (I know it is a dinosaur, but I still miss it). I seem to be doing swimmingly, thanks to code I have quasi-plagiarized. It seems to crap out where i try to pass the selected linetype back to the layer. I get the nastygram "Command: ; error: no function definition: GETLINETYPE" right after selecting the linetype from the dialog.
Any help (and explanation) would be greatly appreciated.
Code below...
x(defun c:CX (/ Sel EntList DataList cnt Num ClrNum EntData)
(if (setq Sel (nentsel "\n Select object to change layers color and linetype: "))
(progn
(if (> (length Sel) 2)
(setq EntList (cons (car Sel) (last Sel)))
(setq EntList (cons (car Sel) EntList))
(setq DataList
(mapcar
'(lambda (x / EntData)
(setq EntData (entget x))
(cons (cdr (assoc 0 EntData)) (cdr (assoc 8 EntData)))
EntList
(setq cnt 0)
(textscr)
(prompt "\n Select number of layer to change color: ")
(foreach lst DataList
(prompt (strcat "\n " (itoa cnt) " - " (cdr lst) " - Object [ " (car lst) " ]"))
(setq cnt (1+ cnt))
(while
(and
(not (setq Num (getint (strcat "\n Select number between 0 - " (itoa (1- cnt)) ": "))))
(not (< 0 Num (1- cnt)))
(graphscr)
(if (and Num (setq ClrNum (acad_colordlg 0)))
(progn
(setq EntData (entget (tblobjname "Layer" (cdr (nth Num DataList)))))
(entmod
(subst
(cons 62 ClrNum)
(assoc 62 EntData)
EntData
; (graphscr)
(vl-load-com)
(if (and Num (setq lt (vla-get-linetype (tblobjname "Layer" (cdr (nth Num DataList)))))))
(progn
(setq EntData1 (entget (tblobjname "Layer" (cdr (nth Num DataList)))))
(setq CL (getvar "CELTYPE"))
(initdia)
(command "_.LINETYPE")
(while (= (logand (getvar "CMDACTIVE") 😎 1) (command pause))
(if (/= (getvar "celtype") CL)
(setq SL (getvar "celtype"))
(setq SL CL)
(setvar "celtype" CL)
SL
(setq LTYPE1 (sl))
(entmod
(subst
(cons 8 lt)
(assoc 8 LTYPE1)
EntData1
(command "_.Regen")
(princ)
@Anonymous wrote:.... The idea would be to have the lisp allow the user to select a nested x-ref entity, and change the color and linetype of the selected layer....
Quickly [on my way out the door] -- could it be as simple as this? For one entity:
(setq lay (cdr (assoc 8 (entget (car (nentsel "\n Select object to change layers color and linetype: "))))))
whatever method you choose to get the User to designate YourColor and YourLinetype
(command "_.layer" "_color" "YourColor" lay "_ltype" "YourLinetype" lay "")
If more than one nested entity is selected, have it put their Layer names into a comma-delimited string instead of into a list, put that into a variable in place of the 'lay' variable in the (command) function, and the Layer command will change those properties of all of those Layers at once.
You are right, in that it is that easy. My challenge is in passing the selected linetype (selected in the portion of the code that pulls up the linetype dialog)
(vl-load-com)
(progn
(initdia)
(setq SL CL)
SL
(setq LTYPE1 (sl))
(entmod
(subst
(cons 8 lt)
(assoc 8 LTYPE1)
EntData1
to the layer command. Maybe I am misunderstanding your suggestion, though.
(initdia)
I notice one thing.... I believe the test in the (while) function will never be satisfied. As I understnad (logand), I don't think (logand {anything} 😎 can ever equal 1. So I think it's not ever going to pause. I believe you want to check whether it equals 8, rather than 1.
I looked at it a little more closely [I haven't ferreted out exactly what everything is doing], and added indentation and identifying notes to make it easier to read what's happening, and I have some comments/questions:
(progn; then
); end if
(setq DataList
(mapcar
); lambda
EntList
); end mapcar
); end setq
(setq cnt 0)
(textscr)
(setq cnt (1+ cnt))
); end foreach
(while
(and
); end and
); end while
(graphscr)
(progn
(entmod
(subst
(cons 62 ClrNum)
(assoc 62 EntData)
EntData
); end subst
); end entmod
); end progn
;;;;; MISSING ); end if somewhere in here?
; (graphscr)
(vl-load-com); this can't be meant for an 'else' argument, but that's where it
;;;;; falls if the (if) function above isn't closed.
(progn ; then
;;;;; Any reason not to just re-use the EntData variable from the color portion?
;;;;; Would need to set it again here, and wouldn't need the additional variable name.
(initdia)
;;;;; Despite my earlier reply, I find in some experimenting that the
;;;;; above is actually expendable [the dialog box takes care of it].
(if (/= (getvar "celtype") CL); if User chose linetype other than what WAS current,
(setq SL (getvar "celtype")); then -- set that into SL
(setq SL CL); else -- set what WAS current into SL
;;;;; Could simply do the 'then' line without the (if) wrapper --
;;;;; The Linetype command/dialog box will set CELTYPE, and whether or
;;;;; not it's different from what was current before, that's what you want in SL
); end if
(setvar "celtype" CL); else
;;;;; Isn't that the same as doing nothing? User didn't pick a different linetype,
;;;;; so there's nothing to do, so omit the 'else' argument.
SL
); end progn
;;;;; do you really want to end 'then' there, or continue with the rest INSIDE the 'then' argument?
;;;;; MISSING ); end if somewhere in here? or:
(setq LTYPE1 (sl)) ;;;;; is this supposed to be an 'else' argument?
;;;;; No (sl) function defined --
;;;;; Should the above be (setq LTYPE1 SL)?
;;;;; Is there any need for LTYPE1 variable separate from SL?
(entmod
(subst
(cons 8 lt)
;;;;; But lt is already its linetype --
;;;;; Should this be (cons 8 SL) to make the NEW linetype a Layer assignment?
;;;;; Or if there's a need for different SL and LTYPE1 variables, (cons 8 LTYPE1)?
;;;;; Or since the Linetype command will have set CELTYPE and that goes into
;;;;; both SL and LTYPE1, could this just be (cons 8 (getvar 'celtype)), and can
;;;;; you skip the CL and SL and LTYPE1 variables entirely?
(assoc 8 LTYPE1)
;;;;; But LTYPE1 would need to be an entity data list -- should this be (assoc 8 EntData1)?
EntData1
); end subst
); end entmod
); end if
(command "_.Regen")
); end progn
); end if
(princ)
);;;;; is this the end defun from code prior to the top of the posted code?
Flubbed a couple of things up -- this part:
SL
should be more like this:
(setvar "celtype" CL) ;;;;; [that's OK -- I misunderstood in two diffeent ways before....]
SL ;;;;; don't know what this is here for
and this part should be omitted:
Looked yet a little deeper, and found a few other things..... This seems to work, in limited testing [wipe out my comments, etc., if it works for you, too], though I think it could be simplified further:
(progn ; then
); end if
(setq DataList
(mapcar
); lambda
EntList
); end mapcar
); end setq
(setq cnt 0)
(textscr)
(setq cnt (1+ cnt))
); end foreach
(while
(and
); end and
); end while
(graphscr)
(progn
(entmod
(subst
(cons 62 ClrNum)
(assoc 62 EntData)
EntData
); end subst
); end entmod
); end progn
); end if ;;;;; I added this
; (graphscr)
;;;;; (if (and Num (setq lt (vla-get-linetype (tblobjname "Layer" (cdr (nth Num DataList))))))); not a vla object!
(if (and Num (setq lt (cdr (assoc 6 (entget (tblobjname "Layer" (cdr (nth Num DataList))))))))
;;;;; could do (vlax-ename->vla-object conversion instead of (cdr (assoc 6....
(progn ; then
(initdia)
;;;;; (while (= (logand (getvar "CMDACTIVE") 😎 1) (command pause)) ;;;;; I commented out
); end if
;;;;; SL ;;;;; Don't know what this is here for -- I commented out
;;;;; ); end progn ;;;;; I commented out -- moved below
;;;;; (setq LTYPE1 (sl)) ;;;;; is this supposed to be an 'else' argument? I commented out
;;;;; (setq LTYPE1 SL) ;;;;; I substituted, but commented out
(entmod
(subst
;;;;; (cons 8 lt) ;;;;; should be 6, not 8
(cons 6 SL) ;;;;; I substituted
;;;;; (assoc 8 LTYPE1) ;;;;; should be 6, not 8
(assoc 6 EntData1) ;;;;; I substituted
EntData1
); end subst
); end entmod
); end progn/then ;;;;; I moved this here from commented-out location above
); end if -- selected something
(command "_.Regen")
); end progn
); end if
