change attrib height of selected objects only
13 REPLIES 13
Message 1 of 14
337 Views, 13 Replies
I have been working with various routines to find a way to change the attribute text height of only select blocks. I always seem to end up changing every attribute in the drawing.
For example, if I place the same block side-by-side in the drawing and want to change the attributes text size of one without it affecting the other.
Jason
13 REPLIES 13
Message 2 of 14
(defun chng_att_hgt ( en attrib hgt / obj
atts)
  (if (and en (setq obj
(vlax-ename->vla-object en)) (= (vlax-get-property obj 'HasAttributes)
:vlax-true))
    (foreach attobj
(vlax-safearray->list (variant-value (vla-getattributes obj)))
size=2>                (if
(= (vlax-get-property attobj 'TagString) attrib)
size=2>
(progn
size=2>                       (setq
ed (entget (vlax-vla-object->ename attobj))
size=2>                                ed
(subst  (cons 40 hgt)(assoc 40 ed) ed)
size=2>                       )
size=2>
(entmod ed)
size=2>
size=2>                  )
TDP
size=2>
size=2>
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
attribute in the drawing. For example, if I place the same block side-by-side
affecting the other. Regards, Jason
Message 3 of 14
Hi Princess,
Just curious, why not
(vlax-for attobj (vla-getattributes
obj)))
instead of
(foreach attobj (vlax-safearray->list
HTH
Humans are born with a wide horizon.
As time goes by, the horizon narrows
and
narrows, until it becomes a point of view.
atts)
:vlax-true))
    (foreach attobj
size=2>                (if
size=2>
(progn
size=2>                       (setq
size=2>                                ed
size=2>                       )
size=2>
(entmod ed)
size=2>
size=2>                  )
TDP
size=2>
size=2>
I
changing every attribute in the drawing. For example, if I place the same
size of one without it affecting the other. Regards,
Jason
Message 4 of 14
LOL!
you're so right!
TDP
Hi Princess,
obj)))
instead of
HTH
narrows and
atts)
:vlax-true))
    (foreach attobj
obj)))
size=2>                (if
size=2>
(progn
size=2>                       (setq
size=2>                                ed
size=2>                       )
size=2>
(entmod ed)
size=2>
size=2>                  )
TDP
size=2>
size=2>
I
Jason
Message 5 of 14
horizon narrows and
LOL!
you're so right!
TDP
Hi Princess,
obj)))
instead of
(foreach attobj
obj)))
HTH
narrows and
atts)
:vlax-true))
    (foreach attobj
obj)))
size=2>                (if
size=2>
(progn
size=2>                       (setq
size=2>                                ed
size=2>                       )
size=2>
(entmod ed)
size=2>
size=2>                  )
TDP
size=2>
size=2>
I
text size of one without it affecting the other. Regards,
Jason
Message 6 of 14
Ian_Bryant
because it does not work.
Regards Ian
Message 7 of 14
Works fine if you know a little vlisp.
recommend that you put this line in your start up
lisp
(vl-load-com)
then your lisps can use the oop stuff in vlisp.
TDP
because it does not work. Regards Ian
Message 8 of 14
like this
atts)
   (vl-vload-com)
:vlax-true))
    (foreach attobj
size=2>                (if
size=2>
(progn
size=2>                       (setq
size=2>                                ed
size=2>                       )
size=2>
(entmod ed)
size=2>
size=2>                  )
usage
(setq en (car (entsel "\nSelect
Block"))
size=2>        attrib (getstring
"\nAttribute Name?")
        hgt
(getdist "\nNew Height?")
(chng_att_hgt en attrib hgt)
TDP
ws:6139031@discussion.autodesk.com...
Hi, because it does not work.
Regards Ian
Message 9 of 14
Ian_Bryant
Sorry I should have been a bit more clear.
Your code works fine.
I was commenting that vlax-for
does not work on (vla-getattributes obj)
as the getattributes method returns a
variant containing a safearray
& not a collection.
Regards Ian
Message 10 of 14
Ian_Bryant
& not a collection.
Regards Ian
Message 11 of 14
so Iwasn't out to lunch the first time
eh?
thanks
TDP
Sorry I should have been a bit more clear. Your code works fine. I was
commenting that vlax-for does not work on (vla-getattributes obj) as the
getattributes method returns a variant containing a safearray & not a
collection. Regards Ian
Message 12 of 14
Princess,
I was trying to understand the code, but I'm having a little trouble.
Instead of identifying which attribute to change, I simply would like to have it change every attribute for every entity selected.
For example, if I wanted to call your routine, I would have this:
{code}
(defun c:gg ( / )
(setq objset (ssget))
(foreach obj
(chng_att_hgt obj "Install Text" 6)
);foreach
);defun
{code}
Message 13 of 14
stevor
The 'foreach' is for elements of a list,
and ssget returns a 'selection set'.
To use foreach you must make a loist of the set 'objset' or,
step thru the set by indexing; many examples exist and one is just below.
We use a set to list converter so:
(foreach obj (ss_lss objset) ; each obj in objset
);foreach
; SS_LST Selection set to list
(defun ss_Lss (ss / L i ) (setq i 0 )
(repeat (if ss (ssLength ss) 0 ) ;to ist
(setq L (cons (ssname ss i ) L ) i (1+ i)) ) L );ed
S
Message 14 of 14
I just changed the foreach to a while and I'm good, thx for the slap on the forehead stevor!
Jason
”Boost
