Visual LISP, AutoLISP and General Customization
cannoscale
6 REPLIES 6
Moshe-A
1671 Views, 6 Replies
cannoscale
Hi Guys,
cannoscale applies the current annoscale to all objecs...i would
like to apply it to specific objects?
thanks
Moshe
6 REPLIES 6
Hallex
in reply to: Moshe-A
My guess is create block instead
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Moshe-A
in reply to: Hallex
Hallex,
So? blocks have a special treatment?
i'm using blocks by the way
my problem is:
have some dynamic attribute blocks (contain some attributes) which have annotative text style
stored in a tool palettes at xScale=1 and i would like to create a comparable  set of block with
xScale=-1 (to make it easier to user) but there i found a 'bug' in database when dragging a block
from tool palettes with X=-1 (see my prevous thread here) and i decide to put it in a container block
and as this one dragged...i explode it but autocad does not apply the current annoscale to attributes
only changing the cannoscale does it but it does to all objects (takes to much time)
thank you
Moshe
pendean
More than one block, one for each instance you need as you note, is probably what was meant: or get into creating Dynamic Blocks perhaps, although it might take some effort with your exact need. You cannot apply CANNOSCALE per object.
Moshe-A
in reply to: pendean
i do use dynamic blocks
pendean
Great: you might find better help with customizing them/it at this forum: http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
Moshe-A
Pendean,
Are you impling Flip Property/Action?
Sounds like you are suspecting me that i do not know dynamic blocks?  Smiley Happy
well, i do know every thing i need to know about them, in fact i do use flip to mirror from up to down and for the other side i need it to be inserted as mirrored (that is the request from my application)
anyway thank you very much for your help
and a many thanks for what you are doing to this Forums
Moshe
”Boost
