This might help....
Goto options and look under the AEC Editor Tab. Make sure Optimize for
Speed is UNchecked.
"Under Object Snap, select Optimize for Speed to limit certain display
representations to respond only to the Node and Insert object snaps.
This setting affects stair, railing, space boundary, multi-view
block, masking block, slice, and clip volume result
(building section) objects. "
CJ
"Vince" wrote in message
news:BAD1D516DF012CBFE2D6245487086706@in.WebX.maYIadrTaRb...
> I don't need the grips, I had tried the gripblock (or options/ selection/
> enable grips within blocks), but it still does not allow me to snap to
> geometry within that block. I can not snap to any endpoints, midpoints,
> centerpoints, etc. at all. If I use an osnap override, it will not
> recognize anything except insertion point.
