Visual LISP, AutoLISP and General Customization
Can someone merge these two "align object" routines
2 REPLIES 2
mjs9199
397 Views, 2 Replies
I've gotten these two routines from different threads on here.
One works with *text and blocks.  The second works with multileaders.
I'd like to merge the two so one command can work with a selection set of any of the above objects (assume selection set of mixed objects - some multileaders, some text, some blocks)
	(defun c:at ( / ss ang *error*)
		(vl-load-com)
		(ErrorHandler '("cmdecho" "osmode"))
			(setvar "cmdecho" 0)
			(setvar "osmode" 576)
		(setq
			ss (ssget '((0 . "*TEXT,INSERT")))
			ang (getangle "\nSelect two points along desired alignment:"))
		(mapcar
			'(lambda (x)
				(vla-put-rotation
					(vlax-ename->vla-object x)
					ang))
			(mapcar 'cadr (ssnamex ss)))
		(*error* nil))
	(defun c:test (/ ss ang i sset)
		(vl-load-com)
		; Tharwat 17. 05. 2011
	  (if
	    (and
	      (setq ss (ssget ":L" '((0 . "MULTILEADER"))))
	      (setq ang (getangle "\n Specify Rotation Angle :")))
	    (repeat
				(setq i (sslength ss))
	      (setq sset (ssname ss (setq i (1- i))))
	      (vla-put-TextRotation (vlax-ename->vla-object sset) ang))
	    (princ))
	  (princ))
Or see C:AT and C:TEST in the attached file
2 REPLIES 2
stevor
in reply to: mjs9199
1. To use different object snaps for two selections of the angle points
you can select the points first, then use ;angle to the the angle:
    (setvar "osmode" 576) ; NEA+INS 110712
    (setq p1 (getoint "\n Angle Pt 1: ")) ;
    (setvar "osmode" 704 )   ; NEA+PER+INS 110708
    (setq p2 (getoint p1 "\n Angle Pt 1: ")) ; relative indicated
    (setq ang (angle p1 p2)) ;a 'REAL number
    (setq angstr (angtos ang)) ; a 'STRING
2. The 'merge' idea, is not clear to me.
S
pbejse
  (vl-load-com)
   (if
     (and
  (setq ss (ssget ":l" '((0 . "*TEXT,INSERT,MULTILEADER"))))
     (repeat
       ((if (eq (cdr (assoc 0 (entget sset))) "MULTILEADER")
        vla-put-TextRotation vla-put-rotation) (vlax-ename->vla-object sset) ang)
   (princ))
”Boost
