Visual LISP, AutoLISP and General Customization
Can I change plot style with lisp?
11 REPLIES 11
Message 1 of 12
3333 Views, 11 Replies
Is there a way for me to change a layers plot style from one to another with
LISP?
We use named plot styles, STB's not CTB's.
I want to be able to create an icon that will change all layers with the
plotstyle "normal" to "black".
Is this possible with lisp?
11 REPLIES 11
Message 2 of 12
rebel
Alex, the following code has no error checking, assumes the drawing is already in Style dependant mode, and Style "Black" is in the currently defined STB.
;;;James Buzbee
(defun jb:NormaltoBlack( / )
(setq layers(vla-get-layers(vla-get-ActiveDocument(vlax-get-acad-object))))
(vlax-for l layers
(progn
(if (= (vlax-get-property l 'PlotStyleName) "Normal")
(vlax-put-property l 'PlotStyleName "Black")
Message 3 of 12
scotts
in reply to: rebel
James,
I can get the lisp to load, but can't seem to get it to run.  Also can I repeat the code if I have multiple plot styles I want to replace (i.e. style_01 with black, style_02 with Screened50, etc...)
Your help is greatly appreciated!
-Scott
Message 4 of 12
pdx271
Remove the "?" in VLIDE, there was a mystery question mark once i pasted into VLIDE.
It does not show here.
- I modified it for my needs.
(defun NormaltoFS (/)
  (setq layers (vla-get-layers
   (vla-get-ActiveDocument (vlax-get-acad-object))
  (vlax-for l layers
    (progn
 (vlax-put-property l 'PlotStyleName "Full Saturation")
Message 5 of 12
SoftwareSupport
Not sure if you guys are still alive but...
What if I wanted to exclude a few layers from this routine:
(defun c:WPS    (/)
  (vlax-for l layers
    (progn
    (vlax-put-property l 'PlotStyleName "Medium")
Message 6 of 12
pbejse
in reply to: SoftwareSupport
(defun c:WPS    (/)
  (vlax-for l layers
    (progn
      (if (and (= (vlax-get-property l 'PlotStyleName) "Normal")
               (not (member (strcase (vla-get-name l)) '("EXCLUDEDLAYER1" "EXCLUDEDLAYER2"))))
HTH
Message 7 of 12
SoftwareSupport
in reply to: pbejse
That did it! Problem solved. Thanks a ton!
Message 8 of 12
gustavobernardi
in reply to: pbejse
I've tried changing "Normal" with "None" and "Medium" with my plotstyle name, but it doesn't work...
I would like to make a routine that defines a specific plot style in the model if the current plotstyle is "None"
What a need to modify?
TIA
(defun c:WPS    (/)
  (vlax-for l layers
    (progn
      (if (and (= (vlax-get-property l 'PlotStyleName) "None")
    (vlax-put-property l 'PlotStyleName "Ringo 1-50")
Message 9 of 12
pbejse
in reply to: gustavobernardi
If the plot stylename "None" "Medium" and "Ringo 1-50" exists, there is no reason why the snippet would not work.
Try setting the current plot stylename to "Ringo 1-50" before running the code, easiest way is with.
(command "-plotsyle" "_Current" "Ringo 1-50")
HTH
Message 10 of 12
gustavobernardi
in reply to: pbejse
Humm, interesting... Now I see. My problem is that I am trying with CTB ant this functions is for STB.
Is there any way to do that with CTB?
Message 11 of 12
DannyNL
If you only want to set the CTB for the Model (or any other) layout, you need to use the Layout object.
The code below will give you the CTB for the current layout in the drawing.
If the value is an empty string "" then it is set to 'None'.
(setq CurDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(vla-get-StyleSheet (vla-get-ActiveLayout CurDoc))
Use this to directly get the value for the StyleSheet property for any layout without worrying if it's the current one or not
(vla-get-StyleSheet (vla-item (vla-get-Layouts CurDoc) "NameOfLayout"))
;;; example
(vla-get-StyleSheet (vla-item (vla-get-Layouts CurDoc) "Model"))
To set the CTB use 'put' instead of 'set' like the code below.
Make sure the CTB name provided exists otherwise you will get an error.
(vla-put-StyleSheet (vla-item (vla-get-Layouts CurDoc) "Model") "acad.ctb")
;;; or even better with error trapping
(vl-catch-all-apply 'vla-put-StyleSheet (list (vla-item (vla-get-Layouts CurDoc) "Model") "acad.ctb"))
To get a list of available plot styles (CTB & STB) use the GetPlotStyleTableNames on any of the layout objects.
This can be used to check if the CTB exists prior to trying to set the StyleSheet property.
(vlax-safearray->list (vlax-variant-value (vla-GetPlotStyleTableNames (vla-get-ActiveLayout CurDoc))))
Message 12 of 12
gustavobernardi
in reply to: DannyNL
Fantastic. Here is the final Code:
(defun c:set-ps()
(vl-load-com)
(setq installed_ps(vlax-safearray->list (vlax-variant-value (vla-GetPlotStyleTableNames (vla-get-ActiveLayout CurDoc)))));;get the plotstyles
(if (= (vl-position "Ringo 1-50.ctb" installed_ps)nil)(c:penasringo));;verify if the plotstyle exist, if not - install
(setq cur_ps(vla-get-StyleSheet (vla-item (vla-get-Layouts CurDoc) "Model")));;get the actual plotstyle
(if (= cur_ps "")(vl-catch-all-apply 'vla-put-StyleSheet (list (vla-item (vla-get-Layouts CurDoc) "Model") "Ringo 1-50.ctb")));;if the user don't choose put the plotstyle
Thank you!
”Boost
