Visual LISP, AutoLISP and General Customization
calling bedit via lisp
7 REPLIES 7
Message 1 of 8
jseefcoot
577 Views, 7 Replies
I'm trying to add the BEDIT command to my command macros, which I redefine using LISP. I have no problems getting the command to work, but I want to see the dialog box. It doesn't work even when I use INITDIA; it requests the block name on the command line instead.
Here is the line from my LISP file:
(defun c:BB () (INITDIA) (command "BEDIT") )
I have tried this using .BEDIT and -BEDIT, and neither gives me the dialog box, although they will all work for calling up the command. I have also tried omitting INITDIA, but that doesn't work either.
What am I missing?
7 REPLIES 7
Message 2 of 8
bnarum1
in reply to: jseefcoot
I might be over simplifing but why not just add BB to your pgp file instead of creating a routine to run a routine.
If you add your custom shortcut keys to the end of the pgp file it will overwrite the previous loaded definition. By placing at the end of the pgp file you can easily copy to next pgp file for next autocad release.
B
Message 3 of 8
jseefcoot
I've always done it with LISP simply because it's a little faster for me to carry around with me from workstation to workstation. (Mostly because I am used to it, having done it this way for years). I have to work on several different computers and simply got in the habit of always keeping a disk or flashdrive with my macros and customizations on it. Doing this with the pgp file is a little cumbersome; using LISP I can call up just the macros, without overwriting the pgp file of the person I am helping.
Message 4 of 8
Testing in 2007 and 2008:
(command ".bedit "); <-note the extra space
fails but then if I hit the Up Arrow once I get the dialog.
Very strange.
This works in 2007 and 2008.
(vla-sendcommand
(vla-get-activedocument
(vlax-get-acad-object))
"bedit ");<- note the extra space.
Autodesk Discussion Group Facilitator
Message 5 of 8
jseefcoot
Yes, I can reproduce that here. That IS pretty strange.
As far as this other piece of code, how do I incorporate that into my LISP file and retain the desired 'BB' alias?
Message 6 of 8
(defun c:bb ()
(vla-sendcommand
"bedit "
(princ)
wrote in message news:5699156@discussion.autodesk.com...
Message 7 of 8
jseefcoot
That works great!!
Thanks for the speedy solution.
Message 8 of 8
You're welcome. One thing you might do is add
(vl-load-com) to make sure the vl-* functions work.
wrote in message news:5699159@discussion.autodesk.com...
That works great!!
”Boost
