Hi everybody,
I am trying to call a lisp command, which is predefined as a function with "( defun c:drow......)" in another file which is loaded in the startup suit.
Basically I am trying to to write a lisp in which end I want to call the command "drow". Unfortunately that doesn’t work.
Even if I type on the command line (command "drow") the result is "Unknown command". But if I type only "drow" everything is fine.
How I can call that/any predefined lisp command from another lisp?
Many thanks in advance.
Chavi
Solved by ivanov.chv. Go to Solution.
Solved by ВeekeeCZ. Go to Solution.
