I've been using the same .lsp file for years to set my command macros. It's old-school, but I like it. I've carried this file across several types of jobs. I am now at a new job using Mechanical 2013. I would like to add a couple of the AM commands to my macros, but they won't work.
Example of one that works:
(defun C:D ( ) (command "DIST"))
A mechanical command that won't:
(defun C:SA ( ) (command "AMSCAREA"))
I have tried prefixing the command with underscore, period, hyphen, etc and still no dice. Does anyone know a way to call AM commands via LISP?
Thanks for any help
Solved by kefer_kb. Go to Solution.
Solved by hmsilva. Go to Solution.
Thanks for the reply. Sadly, it didn't work.
Any other suggestions out there?
jseefdrumr,
another attempt
using the ActiveX SendCommand method
(vl-load-com)
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "AMSCAREA"))
Henrique
@jseefdrumr wrote:I've been using the same .lsp file for years to set my command macros. It's old-school, but I like it. I've carried this file across several types of jobs. I am now at a new job using Mechanical 2013. I would like to add a couple of the AM commands to my macros, but they won't work.
Thanks for any help
The documentation doesn't mention this, but on a few tests seems to me that the command and vl-cmdf functions only work for vanilla AutoCAD built-in commands and some but not all AutoCAD Mechanical commands.
- and none of my own commands created by (defun c:something ()...)
So, they probably just forgot adding the AMSCAREA command to the system.
The suggestion by kefer.kb works for me on AcadM 2012.
Thanks very much to Franz and Henrique. Using the (c:amscarea) method worked. Henrique suggested it originally, but I coded it incorrectly. Franz's post showed me the error I made that I overlooked. I am now up and rolling with my newly-macro'd AM commands. You guys rock!
