Here is another example:
(setq a (cal)) = 2.0
(setq b (cal)) = 3.0
Command: Cal
>> Expression: a+b
5.0
Good Luck!
Luis
Jorge Álvarez González wrote in message
<114E7F9A7A6B52BF56C0D947265FC8C6@in.WebX.SaUCah8kaAW>...
>Thanks Luis. You have saved me hours of typing. However, if you use the
>variable inside the CAL command it must be between quotes
>('*expression*'...), because it uses the *. You may also change the
variable
>name.
>Jorge
