Thanks Robert, you are correct my issue was macro syntax, not differances
between acad R14 and Acad2002(chair-to-keyboard interface problems can be
the worst:).
"R. Robert Bell" wrote in message
news:ADD2B6348F2F331256E6BDCAC8588A19@in.WebX.maYIadrTaRb...
> Scott,
> ^C^C-layer;N;QCIRCLE;c;3;QCIRCLE;;(c:ChgLay"QCIRCLE");+
> _-INSERT;QCIRCLE;\4;4;;;;;;;DDATTE;LAST;(c:ResLay)
> Notice the removal of the extraneous pause and after the DDAttE
> command...
> Also, I see nothing in the menu macro that explicitly sets AttDia to 0, so
> that is something to think about.
> R. Robert Bell, MCSE
> www.AcadX.com
> "Scott R Smith" wrote in message
> news:EC54462BC7B666170FBC50B8C08C98C3@in.WebX.maYIadrTaRb...
> | For R14, I had mymenu.mns and mymenu.mnl set up so that when I inserted
my
> | blocks from my menus and toolbuttons: the current layer state was saved
> | prior to inserting the block(C:Clayer) then a new layer was created and
> the
> | block was inserted, Then would revert to the previous layer (c:reslay).
> | However when I loaded these menus to Acad2002, non of this works, then
new
> | layer is created and the block is inserted. Has anyone run into run into
> | this issue? I have pasted a sample menu macro, and my mymenu.mnl entry
> below
> | Thanks in advance.
> | **Typical Block insertion macro***
^C^C-layer;N;QCIRCLE;c;3;QCIRCLE;;(c:ChgLay"QCIRCLE");_-INSERT;QCIRCLE;\4;4;
> | ;;;;;;DDATTE;LAST;\;(c:ResLay)
> | ***.mnl entry***
> | (defun c:ChgLay (l)
> | (setq GV:Slay (getvar "CLAYER"))
> | (setvar "CLAYER" l)
> | (princ)
> | ) ;_ end of defun
> | ;;; (c:ResLay )
> | ;;; Revives the layer set by c:ChgLay
> | (defun c:ResLay ()
> | (setvar "CLAYER" GV:Slay)
> | (princ)
> | ) ;_ end of defun
