Visual LISP, AutoLISP and General Customization
(C:Reslay) not working in Acad2002
3 REPLIES 3
148 Views, 3 Replies
For R14, I had mymenu.mns and mymenu.mnl set up so that when I inserted my
blocks from my menus and toolbuttons: the current layer state was saved
prior to inserting the block(C:Clayer) then a new layer was created and the
block was inserted, Then would revert to the previous layer (c:reslay).
However when I loaded these menus to Acad2002, non of this works, then new
layer is created and the block is inserted. Has anyone run into run into
this issue? I have pasted a sample menu macro, and my mymenu.mnl entry below
Thanks in advance.
**Typical Block insertion macro***
^C^C-layer;N;QCIRCLE;c;3;QCIRCLE;;(c:ChgLay"QCIRCLE");_-INSERT;QCIRCLE;\4;4;
;;;;;;DDATTE;LAST;\;(c:ResLay)
***.mnl entry***
(defun c:ChgLay (l)
(setq GV:Slay (getvar "CLAYER"))
(setvar "CLAYER" l)
(princ)
) ;_ end of defun
;;; (c:ResLay )
;;; Revives the layer set by c:ChgLay
(defun c:ResLay ()
(setvar "CLAYER" GV:Slay)
(princ)
) ;_ end of defun
3 REPLIES 3
Scott,
^C^C-layer;N;QCIRCLE;c;3;QCIRCLE;;(c:ChgLay"QCIRCLE");+
_-INSERT;QCIRCLE;\4;4;;;;;;;DDATTE;LAST;(c:ResLay)
Notice the removal of the extraneous pause and after the DDAttE
command...
Also, I see nothing in the menu macro that explicitly sets AttDia to 0, so
that is something to think about.
R. Robert Bell, MCSE
www.AcadX.com
"Scott R Smith" wrote in message
news:EC54462BC7B666170FBC50B8C08C98C3@in.WebX.maYIadrTaRb...
the
below
| Thanks in advance.
| ***.mnl entry***
| (defun c:ChgLay (l)
| (setvar "CLAYER" l)
| (princ)
| ) ;_ end of defun
| ;;; (c:ResLay )
| (defun c:ResLay ()
| (princ)
| ) ;_ end of defun
Thanks Robert, you are correct my issue was macro syntax, not differances
between acad R14 and Acad2002(chair-to-keyboard interface problems can be
the worst:).
"R. Robert Bell" wrote in message
news:ADD2B6348F2F331256E6BDCAC8588A19@in.WebX.maYIadrTaRb...
> Scott,
> command...
> www.AcadX.com
my
> the
new
> below
> | Thanks in advance.
> | ***.mnl entry***
> | (defun c:ChgLay (l)
> | (setvar "CLAYER" l)
> | (princ)
> | ) ;_ end of defun
> | ;;; (c:ResLay )
> | (defun c:ResLay ()
> | (princ)
> | ) ;_ end of defun
(chair-to-keyboard interface problems)
Very good. I will have to remember this one.
Dave Alexander
> the worst:).
> > Scott,
> > command...
> > www.AcadX.com
> my
> > the
> new
> > below
> > | Thanks in advance.
> > | ***.mnl entry***
> > | (defun c:ChgLay (l)
> > | (setvar "CLAYER" l)
> > | (princ)
> > | ) ;_ end of defun
> > | ;;; (c:ResLay )
> > | (defun c:ResLay ()
> > | (princ)
> > | ) ;_ end of defun
”Boost
