if change a vertex of the resulting closed pline in acad the area tag updates dynamically as expected in acad but NOT in map3d. is there a DLL that my map isntall is missing or something??
note1: i am using a DOSlibrary command for placing the tag at the centroid of the closed pline.
note2: this dumbed down version uses your current text style
(defun c:BoundaryTagAreaReactor (/ obj centroid vlaobj plinearea fd oba lu)
(vl-load-com)
(setvar "tilemode" 1)
(setvar "OSMODE" 5)
(setvar "orthomode" 0)
(setvar "lunits" 4)
;;area label should have 2 decimal places
(setvar "luprec" 2)
;;draw pline
(princ "\nDraw the boundary Pline and make sure to type a 'C' to close when done.")
(command "._pline")
;;wait for pline command to finish
(while (= 1 (logand (getvar "CMDACTIVE") 1))
(command PAUSE)
(setq obj (entlast))
(setq centroid (dos_plinecentroid obj)) ;from DOSLib1#.arx
(setq vlaobj (vlax-ename->vla-object obj))
;;close pline if it is not closed
(if (= (vla-get-closed vlaobj) :vlax-false)
(progn
;;it is not closed; close it
(vla-put-closed vlaobj :vlax-true)
;;set pline width
(command "pedit" obj "w" 4 "")
;;calculate area
(setq plinearea (/ (vla-get-area vlaobj) 144.0))
;;create dynamic label
(setq fd (getvar "fielddisplay"))
(if (/= fd 0)
(setvar "fielddisplay" 0)
(setq oba (vla-get-objectid vlaobj))
(setq lu (getvar "lunits"))
(setvar "OSMODE" 0)
(cond
((= lu 2)
(setq lin (strcat "%<\\AcObjProp Object(%<\\_ObjId "
(rtos oba 2 0)
">%).Area \\f \"%lu6%qf1\">%"
((= lu 4)
(rtos oba 2 0)
">%).Area \\f \"%lu2%ct4%qf1 SQ. FT.\">%"
((= lu 5)
(rtos oba 2 0)
">%).Area \\f \"%lu5\">%"
((= lu 3)
(rtos oba 2 0)
((= lu 1)
(rtos oba 2 0)
">%).Area \\f \"%lu1\">%"
(command "mtext" centroid "J" "MC" "W" "0" lin "")
(setq plineReactor
(vlr-object-reactor
(list vlaobj)
"pline Reactor"
'((:vlr-modified . ufa))
;;prompt user to move inserted mtext
(command "move" "l" "" centroid)
(princ "\nMtext showing area is now anchored to last closed Pline.")
(princ)
);defun
