My goal is to activate the lisp & have the block "BOM" burst so that it retains the information but can be purged, then have the blocks "BOM" & "LINDSAY" (nested in "BOM") purged. For the burst portion it makes no difference to me if it selects the "BOM" block in the program or if I have to highlight it. It should be noted that I am a beginner when it comes to lisp, I have some very basic things down which makes me think this can be done, but also could make me dangerous with it too.
This is code that I have written and it has me puzzled, it mimics other code in my Acaddoc.lsp file which is where I have located this as well;
;;;BURST SHORTCUT
(defun c:BU ()
(C:BURST)
(PRINC)
;;;"BOM" PURGE
(DEFUN C:BP ()
(COMMAND "-PURGE" "BLOCKS" "BOM" "no")
(princ)
;;;"LINDSAY" PURGE
(DEFUN C:LP ()
(COMMAND "-PURGE" "BLOCKS" "LINDSAY" "NO")
(princ)
;;;BURST & PURGE
(DEFUN C:BX ()
(C:BU)
(C:BP)
(C:LP)
(PRINC)
The burst shortcut works with no problem, however the "BOMPURGE" & "LINDSAYPURGE" are unknown commands per the command line. I have tried "purge", "_purge" also used the letters B for block & N for no instead of the words, tried the block name with & without the quotes all of which return the same result. From what I have seen in my search of this database my code should work as it appears to match what other have written, which makes me think its something very simple & I am overlooking it.
I also tried;
(DEFUN C:BP ()
(setq blockname "BOM")
(setq ss nil)
(setq ss (ssget "X" (list (cons 2 BOM))))
(if ss
(progn
(command "_BURST" ss "")
(command "_purge" "B" BOM "Y" "")
); progn
); if
which is code that I found on this board by EC-CAD for erasing a block & purging it, replaced the erase command with the burst to no avail. Any help on this would be greatly appreciated.
Solved by pbejse. Go to Solution.
If it (LINDSAY) has attributes use this:
(Defun c:BBL (/ ss mn mn) (vl-load-com) (if (setq ss (ssget "_X" (list '(0 . "INSERT")'(66 . 1)'(2 . "BOM")(cons 410 (getvar 'CTAB))))) (progn (vla-getboundingbox (vlax-ename->vla-object (setq e (ssname ss 0))) 'mn 'mx ) (sssetfirst nil (ssadd e)) (c:burst) (if (sssetfirst nil (ssget "_W" (vlax-safearray->list mn) (vlax-safearray->list mx) '((0 . "INSERT") (66 . 1) (2 . "LINDSAY") ) ) ) (c:burst)) (command "_purge" "BLocks" "BOM,LINDSAY" "_N") )) (princ) )
If not
(Defun c:BBL (/ ss mn mn) (vl-load-com) (if (setq ss (ssget "_X" (list '(0 . "INSERT")'(66 . 1)'(2 . "BOM")(cons 410 (getvar 'CTAB))))) (progn (vla-getboundingbox (vlax-ename->vla-object (setq e (ssname ss 0))) 'mn 'mx ) (sssetfirst nil (ssadd e)) (c:burst) (if (setq ss (ssget "_W" (vlax-safearray->list mn) (vlax-safearray->list mx) '((0 . "INSERT") (66 . 1) (2 . "LINDSAY") ) ) ) (command "_explode" ss)) (command "_purge" "BLocks" "BOM,LINDSAY" "_N") )) (princ) )
Hope this helps
Thank you for the quick response. Yes the block named "Lindsay" does contain attributes. I tried both codes & neither seemed to do anything.
;;;---------------------------------------------------------------------------- ;;;BURST HOTKEY ;;;---------------------------------------------------------------------------- (defun c:BU () (C:BURST) ) (PRINC) ) ;;;---------------------------------------------------------------------------- ;;;"BOM" PURGE ;;;---------------------------------------------------------------------------- (DEFUN C:BOMPURGE () (COMMAND "_purge" "BLocks" "BOM" "_N") (princ) ) ;;;---------------------------------------------------------------------------- ;;;"LINDSAY" PURGE ;;;---------------------------------------------------------------------------- (DEFUN C:LINDSAYPURGE () (COMMAND "_purge" "BLocks" "LINDSAY" "_N") (princ) ) ;;;---------------------------------------------------------------------------- ;;;BURST PURGE ;;;---------------------------------------------------------------------------- (DEFUN C:BX () (C:BU) (C:BOMPURGE) (C:LINDSAYPURGE) (PRINC) )
This is my code now, after re apploading I get BU, BOMPURGE & LINDSAYPURGE, to work seperatly & in the order, but my system still does not recognize the BX command
Reasons the code might not work or "neither seemed to do anything"
* (setq ss (ssget "_X" (list '(0 . "INSERT")'(66 . 1)
'(2 . "BOM")<-----Block "BOM" Not found, could be "anonymously named block" <"*U4">, in this case we may need to use '(2 . "`*U*,BOM") and
check each block effectivename
* Block explodable property is 0
* pickfirst is 0
(sssetfirst nil (ssadd e))<--- wont work at all
* (ssget "_W" <----- selection area must be visible on screen so (command "_zoom" "Object"...) would be invoke
'((0 . "INSERT")
(66 . 1)
(2 . "LINDSAY")
@Anonymous wrote:This is my code now, after re apploading I get BU, BOMPURGE & LINDSAYPURGE, to work seperatly & in the order, but my system still does not recognize the BX command
As for your code
(defun c:BU ()
(C:BURST)
(PRINC)
I am not sure why but when I type the code to match the corrections you made to mine it does not work, but if i copy & paste & changed the BU to BZ it works. Thank you for your assistance.
