hello again!!!!!
I am working in a new lips....it works correctly but have a problem.I have to press intro always that message box appears.how i can fix it?
The lips:
(vl-load-com) (princ "\OVERKILL BLOQUES. Escribe \"OVERKILLBLOQUES\" para empezar..") (defun c:OVERKILLBLOQUES ( / sele cod ) (if (setq sele (ssget (list '(0 . "INSERT") ))) (progn (setq Cod 0 ) ;;;;;;;;;recorrer elementos de la lista;;;;;;;;;;; (repeat (sslength sele) (setq nombrebloque (vla-get-Effectivename (vlax-ename->vla-object ( ssname sele cod)))) (command-s "_bedit" nombrebloque ) (command-s "_overkill" "_all" "" ) (command-s "_BCLOSE" "") (setq Cod (1+ Cod)) ); end repeat ;;;;;;;;;recorrer elementos de la lista;;;;;;;;;;; (princ) );c.prg );c.if (setvar "cmdecho" 1) (prin1) );c.defun
thanks!!!!!!
Solved by andresep82. Go to Solution.
Solved by hmsilva. Go to Solution.
I think that message box is because you are using "command-s", try to use "command" instead.
I'm not sure when we suppose to use command, and when command-s, I think it depends from autocad version.
Anyway, you are trying to use overkill command in block editor, and I think, overkill is not allowed in block editor.
hummmm.... "-s" It is not the problem, use de lips and see what happen. i need to know how close message box.
On the other hand i use cad2015, Because of it I use -s. and overkill is allowed.
Thank you for your comment¡¡¡¡
@andresep82 wrote:
... i need to know how close message box.
Hi andresep82,
many of us (including me) don't have AC2015 in all machines to test the code , would be useful, if you attach a print screen from the message box...
Meanwhile try to call the "_.-overkill" command, and "_.bsave"
(command "_.-overkill" "_All" "" "")
(command "_.bsave)
(command "_.bclose)
Hoping this helps
Henrique
For 2015 it should be ok, but I think for earlier versions overkill is not allowed (2012 for sure).
When I tried your routine on 2012 it always crashes...
yeeahhhhhhhhh¡¡¡¡¡¡
hmsilva that is the solution:
thanks¡¡¡¡¡¡¡¡¡¡¡¡¡
