block overkill problem
8 REPLIES 8
Message 1 of 9
andresep82
2185 Views, 8 Replies
hello again!!!!!
I am working in a new lips....it works correctly but have a problem.I have to press intro always that message box appears.how i can fix it?
The lips:
(vl-load-com)
(princ "\OVERKILL BLOQUES. Escribe \"OVERKILLBLOQUES\" para empezar..")
(defun c:OVERKILLBLOQUES ( / sele cod )
 (if
(setq sele (ssget (list  '(0 . "INSERT") )))
(progn
   (setq Cod 0 )
 ;;;;;;;;;recorrer elementos de la lista;;;;;;;;;;;
 (repeat
	(sslength sele)
 (setq  nombrebloque (vla-get-Effectivename (vlax-ename->vla-object ( ssname sele cod))))
(command-s "_bedit"  nombrebloque )
(command-s "_overkill" "_all" "" )
(command-s "_BCLOSE" "")
(setq Cod (1+ Cod))
); end repeat
   (princ)
  );c.prg
 );c.if
(setvar "cmdecho" 1)
 (prin1)
);c.defun
 thanks!!!!!!
8 REPLIES 8
Message 2 of 9
dicra
in reply to: andresep82
I think that message box is because you are using "command-s", try to use "command" instead.
I'm not sure when we suppose to use command, and when command-s, I think it depends from autocad version.
Anyway, you are trying to use overkill command in block editor, and I think, overkill is not allowed in block editor.
Message 3 of 9
andresep82
in reply to: dicra
hummmm.... "-s"  It is not the problem, use de lips and see what happen. i need to know how close message box.
On the other hand i use cad2015, Because of it I use -s. and overkill  is allowed.
Thank you for your comment¡¡¡¡
Message 4 of 9
hmsilva
@andresep82 wrote:
... i need to know how close message box.
Hi andresep82,
many of us (including medon't have AC2015 in all machines to test the code , would be useful, if you attach a print screen from the message box...
Meanwhile try to call the "_.-overkill" command, and "_.bsave"
(command "_.-overkill" "_All" "" "")
(command "_.bsave)
(command "_.bclose)
Hoping this helps
Henrique
Message 5 of 9
dicra
For 2015 it should be ok, but I think for earlier versions overkill is not allowed (2012 for sure).
When I tried your routine on 2012 it always crashes...
Message 6 of 9
andresep82
in reply to: dicra
yeeahhhhhhhhh¡¡¡¡¡¡
hmsilva  that is the solution:
thanks¡¡¡¡¡¡¡¡¡¡¡¡¡
Message 7 of 9
hmsilva
You're welcome, andresep82
Glad I could help
Henrique
Message 8 of 9
can you share the lisp?
it will realy help me!! can i download it?
Message 9 of 9
andresep82
Yes,you can use it
”Boost
