Could a .lsp file work with the block editor so that double-clicking a block will make it skip straight to the editor without displaying the "Edit Block Reference" dialoge?
Try this:
;Block Editor shortcut ;written by Abbas Aqdam (defun c:BBE ( / e obj ) (while (/=(type(setq e (car(last(nentsel "\nSelect any BLOCK to edit: "))))) 'ENAME)) (setq obj (vlax-ename->vla-object e)) (if (= (vlax-get-property obj 'ObjectName) "AcDbBlockReference") (command "_.BEDIT" (vlax-get-property obj (if (vlax-property-available-p obj 'effectivename)'effectivename 'name)) );command );if );defun
hope to helps
Abbas
