Just the fact that they're blocks wouldn't necessarily mean you need to do
that. If the elements of the block definition are drawn on Layer Zero,
without override colors assigned, all you would need to do would be to
change the layer the block insertions are on. If the elements are drawn on
other layers, without override colors, all you would have to do would be to
change the colors of those layers, assuming they're their layers and not
yours.
You would only need to do what you describe if the elements within the
blocks have override colors assigned. You could either change the colors
assigned, or make them all Bylayer and do the second half of the preceding
paragraph. I don't have anything myself, but I think you might find some
solutions if you search the Newsgroup.
Kent Cooper
wrote...
It doesnt seem to work that way, i guess because they are blocks, i seem to
have to explode them, edit colour, then redefine
