<etransmit sounds promising. Is it in 2000? And could you explain it
specifically?
E-transmit is a core AutoCAD command that came out of pak-n-go. I am not
sure when it was included in AutoCAD. We are at 2004 now and I have trouble
remembering the diffence between 2002 and 2000i never mind 2000. However, it
works the same way as Pak-N-Go except you have the option of "saving a folder
set of drawings", creating a "zip" file or creating a "exe" file (which is not
recomended as most government e-mail systems will not accept "exe" files). You
also have the option of converting all files included to 2000 dwg format for
e-transmit 2004 and R14 dwg format for e-transmit 2002. You can also create a
e-mail transmittal that can be sent.
<1. When you send to consultants for coordination you "remove the xref
paths" - what does this do for you and how do you do it?
This is part of e-transmit and the reason is we use
hard paths for our xrefs while the norm seems to be relative paths.
<2. When you send to consultants for
their information you "bind the xrefs" - does this preclude the xref from
updating with future changes, and if so do you bind the xrefs and create a
separately named - and separate file for that drawing?
Yes this turns the xref into a block. Some people don't use xrefs and
are confused by the concept. The other thing is that "for your
information" is for viewing and plotting only. They could easily
extract anything out of the drawing that they want easily as well. It is the
same file. We just saveas to a archive sub-directory to have a copy of what we
acturally sent them for our records.
<. For archiving I gather removing the xref paths is similar to binding
the xrefs in that it causes the xrefs to be attached to the drawing without any
ability to update a linked xref.
Yes, however, the Express Tools have a utility for convertng blocks back to
xrefs maintaing the scale and rotation. Archiving by defination is just a copy
of the drawing at a particular point in the drawings history that you may
want to reproduce again for some reason. Think of it as being similar to a file
copy of a letter.
<Finally, should I assume that there is no email equivalent to a .plt
file (my understanding of .plt files is that they cannot be sent to another user
unless you know what their printer driver is - and they would not be able to see
the drawing anyway) which would act similar to a pdf file in the sense that I
could see it, save it, print it, but not alter or edit it..
Plot files are not viewable in AutoCAD although I think that there are some
third party programs that will read and display them. I think that there
is or will be some plt to dwg conversions out there but don't know. I have
a hard enough time keeping up with AutoCAD to worry about the rest of the
"stuff" out there. If you want to give them something they can view and print
then probably pdf is the way to go.
Hope this helps.
Dave Alexander
