I am working on an improvement to a small application I created.
The object of interest is an AutoCAD MEP Pipe...
unfortunately beginning in 2012 autodesk eliminated the top level data in the entity list obtained by (entget (car (entsel))). So I am resorting to VLAX- calls. This isn't bad necessarily.
The part of the app I need to improve adds a pipe object at a pragmatically issued coordinate. The improvement is that I need to test for an existing pipe at a that coordinate and therefore don't add the new object.
So at the first of my application I get the existing pipes of interest and save of a global list made up of pairs of coordinates and entity handles. I thought I could chk this list to see if the coordinate exists in the list... if it does then I check the entity handle to make certain it still is in the dwg.
The question might be... do I need to use an equal function with a fuzz factor somehow... or is there perhaps a better more ingenious way to do this... say like converting the coordinates to a large integer value by first multiplying by 1000. And use this instead of the actual coordinate with a fuzz factor to check for a pre-existing pipe.
How might you suggest?
(((1002.51 906.208 6.375) . "14FE4")
((1060.29 889.366 4.0625) . "14FEA")
((1024.59 896.497 4.0625) . "14FED")
