Hi everyone
I got this code from cadtutor and tried to modify to suit my needs mostly in civil works.
But still having a problem with it.
For example;
top of batter location (blue line) =on top
bottom batter location (red line) =on bottom
the batter symbol is ok.
but when;;;;
top of batter location (blue line) =on bottom
bottom batter location (red line) =on top
the batter symbol is inverted
here's the output that I want to achieve
(vl-load-com)
(defun alg-ang (obj pnt) (- (angle '(0. 0. 0.)(vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pnt)))(/ pi 2))) (defun C:test (/ stepLength endPt startPt divStep) (COMMAND "_UNDO" "_M") (setq acadApp (vlax-get-acad-object)) (setq acadDoc (vla-get-ActiveDocument acadApp)) (setq acSp (vla-get-modelspace acadDoc)) (setq a '(0.0 0.0 0.0)) (command "-insert" "tick" "_s" "1" a "0") (command "_erase" "l" "") (if(not(tblsearch "LAYER" "C-BATR_SYMB")) (command "-layer" "new" "C-BATR_SYMB" "Color" 252 "C-BATR_SYMB" "LTYPE" "Continuous" "C-BATR_SYMB" "")) (setvar "clayer" "C-BATR_SYMB") (setvar "celtype" "bylayer") (setvar "cecolor" "bylayer") (setq distbetween (getreal(strcat"\nSPECIFY DISTANCE BETWEEN BATTER TICKS: "))) (setq divStep distbetween stepLength 0.0 stepLength2 divstep ) (setq BottomObj (vlax-ename->vla-object (car (entsel "\nSELECT TOP OF BATTER>>")))) (setq UpperObj (vlax-ename->vla-object (car (entsel "\nSELECT BOTTOM OF BATTER >>")))) (setq objLength (vlax-curve-getDistAtParam BottomObj (vlax-curve-getEndParam BottomObj))) (while (< stepLength objLength) (setq startPt (vlax-curve-getPointAtDist BottomObj stepLength)) (setq startPt2 (vlax-curve-getPointAtDist BottomObj stepLength2)) (setq endPt (vlax-curve-getClosestPointTo UpperObj startPt) ) (setq endPt2 (vlax-curve-getClosestPointTo UpperObj startPt2) ) (setq ang (alg-ang BottomObj startPt)) (setq ang2 (alg-ang BottomObj startPt2)) (setq dis (distance startPt endPt)) (setq dis2 (/ (distance startPt2 endPt2) 2) ) (setq endPt (polar startPt ang 1.)) (setq endPt2 (polar startPt2 ang2 1.)) (setq Xline (vlax-invoke acSp 'AddXLine startPt endPt)) (setq Xline2 (vlax-invoke acSp 'AddXLine startPt2 endPt2)) (if (setq endPt (vlax-invoke Xline 'IntersectWith UpperObj 0)) (progn (vlax-invoke acSp 'InsertBlock startPt "tick" 1 1 1 (- ang (* pi 2)));<-- change the block name here (vl-cmdf "_.scale" "l" "" startPt dis ) ));end if (vla-delete Xline) (setq stepLength (+ stepLength divStep)) ;end if (vla-delete Xline2) (setq stepLength2 (+ stepLength2 divStep)) ) (vlax-release-object BottomObj) (vlax-release-object UpperObj) (princ) (COMMAND "_UNDO" "_E") )
Solved by marlance. Go to Solution.
Hi,My try with this...
Is not necessary that polyline have constant offset, the scale of block "TICK" is adjusted
(vl-load-com) (defun z_dir (p1 p2 / ) (trans '(0.0 1.0 0.0) (mapcar '(lambda (k) (/ k (sqrt (apply '+ (mapcar '(lambda (x) (* x x)) (mapcar '- p2 p1) ) ) ) ) ) (mapcar '- p2 p1) ) 0 ) ) (defun c:batter ( / js_b ent_b vla_obj_b param_start_b pram_end_b perim_obj pt_start_b deriv alpha js_t ent_t vla_obj_t param_start_t pt_start_t v1 v2 det_or len_vtx d_x pt_ins param_pt pt_first pt_snd dxf_210 scale) (vl-load-com) (princ "\nSELECT BOTTOM OF BATTER >>") (while (not (setq js_b (ssget "_+.:E:S" (list (cons 0 "*POLYLINE") (cons 67 (if (eq (getvar "CVPORT") 2) 0 1)) (cons 410 (if (eq (getvar "CVPORT") 2) "Model" (getvar "CTAB"))) (cons -4 "<NOT") (cons -4 "&") (cons 70 120) (cons -4 "NOT>") ) ) ) ) ) (setq ent_b (ssname js_b 0) vla_obj_b (vlax-ename->vla-object ent_b) param_start_b (vlax-curve-getStartParam vla_obj_b) param_end_b (vlax-curve-getEndParam vla_obj_b) perim_obj (vlax-curve-getDistAtParam vla_obj_b param_end_b) pt_start_b (vlax-curve-getPointAtParam vla_obj_b param_start_b) deriv (vlax-curve-getFirstDeriv vla_obj_b param_start_b) alpha (atan (cadr deriv) (car deriv)) ) (princ "\nSELECT TOP OF BATTER>>") (while (not (setq js_t (ssget "_+.:E:S" (list (cons 0 "*POLYLINE") (cons 67 (if (eq (getvar "CVPORT") 2) 0 1)) (cons 410 (if (eq (getvar "CVPORT") 2) "Model" (getvar "CTAB"))) (cons -4 "<NOT") (cons -4 "&") (cons 70 120) (cons -4 "NOT>") ) ) ) ) ) (if (not (tblsearch "LAYER" "C-BATR_SYMB")) (entmake '((0 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2 . "C-BATR_SYMB") (70 . 0) (62 . 252) (370 . -3) (6 . "Continuous") ) ) ) (setq ent_t (ssname js_t 0) vla_obj_t (vlax-ename->vla-object ent_t) param_start_t (vlax-curve-getStartParam vla_obj_t) pt_start_t (vlax-curve-getPointAtParam vla_obj_t param_start_t) ) (setq v1 (mapcar '- (polar pt_start_b alpha 1.0) pt_start_b) v2 (mapcar '- (vlax-curve-getClosestPointTo vla_obj_t pt_start_b ) pt_start_b ) det_or (apply '(lambda (x1 y1 z1 x2 y2 z2) (- (* x1 y2) (* y1 x2))) (append v1 v2) ) ) (cond ((< det_or 0.0) (setq ang_dir (- (* 0.5 pi)))) ((> det_or 0.0) (setq ang_dir (* 0.5 pi))) ) (if (not (tblsearch "BLOCK" "TICK")) (progn (entmake '( (0 . "BLOCK") (8 . "0") (2 . "TICK") (70 . 2) (62 . 0) (6 . "ByBlock") (370 . -2) (10 0.0 0.0 0.0) ) ) (entmake '( (0 . "LINE") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 0) (6 . "ByBlock") (370 . -2) (100 . "AcDbLine") (10 0.0 0.0 0.0) (11 0.5 -9.18455e-017 0.0) (210 0.0 0.0 1.0) ) ) (entmake '( (0 . "LWPOLYLINE") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 0) (6 . "ByBlock") (370 . -2) (100 . "AcDbPolyline") (90 . 3) (70 . 129) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 0.5 -9.18455e-017) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 0.933013 -0.25) (40 . 0.0) (41 . 0.0) (42 . 0.267949) (91 . 0) (10 0.933013 0.25) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (210 0.0 0.0 1.0) ) ) (entmake '( (0 . "ENDBLK") (8 . "0") (62 . 0) (6 . "ByBlock") (370 . -2) ) ) ) ) (initget 7) (setq len_vtx (getdist "\nSPECIFY DISTANCE BETWEEN BATTER TICKS: ")) (setq d_x 0.0) (while (< d_x perim_obj) (setq pt_ins (vlax-curve-getPointAtDist vla_obj_b d_x) param_pt (vlax-curve-getParamAtPoint vla_obj_b pt_ins) pt_first (vlax-curve-getPointAtParam vla_obj_b (fix param_pt)) pt_snd (vlax-curve-getPointAtParam vla_obj_b (1+ (fix param_pt))) deriv (vlax-curve-getFirstDeriv vla_obj_b param_pt) alpha (atan (cadr deriv) (car deriv)) ) (if (null pt_snd) (setq pt_snd (vlax-curve-getEndPoint vla_obj_b)) ) (setq dxf_210 (z_dir pt_first pt_snd) scale (distance pt_ins (vlax-curve-getClosestPointTo vla_obj_t pt_ins))) (entmake (list (cons 0 "INSERT") (cons 100 "AcDbEntity") (assoc 67 (entget ent_b)) (assoc 410 (entget ent_b)) (cons 8 "C-BATR_SYMB") (cons 100 "AcDbBlockReference") (cons 2 "TICK") (cons 10 (trans (vlax-curve-getPointAtDist vla_obj_b d_x) 0 dxf_210)) (cons 41 scale) (cons 42 scale) (cons 43 scale) (cons 50 (+ alpha ang_dir)) (cons 210 dxf_210) ) ) (setq d_x (+ d_x len_vtx)) ) (prin1) )
@CADaSchtroumpf wrote:Hi,My try with this...
Hi
works fine now but I want to change the shape of the batter with the drawing attached below.
I tried to modify the entmaking of the line and polyline but still can't manage to change shape of the batter.
(entmake '( (0 . "LINE") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 0) (6 . "ByBlock") (370 . -2) (100 . "AcDbLine") (10 0.0 0.0 0.0);;;;;is this the first point of the line? (11 0.5 -9.18455e-017 0.0);;;;second point of the line?
(210 0.0 0.0 1.0)
and how about the polyline?
how can i change the shape?
For change the shape, replace
(if (not (tblsearch "BLOCK" "TICK")) (progn ... ... ) )
by this:
(if (not (tblsearch "BLOCK" "TICK")) (progn (entmake '( (0 . "BLOCK") (8 . "0") (2 . "TICK") (70 . 2) (62 . 0) (6 . "ByBlock") (370 . -2) (10 0.0 0.0 0.0) ) ) (entmake '( (0 . "LINE") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 0) (6 . "ByBlock") (370 . -2) (100 . "AcDbLine") (10 0.0 0.0 0.0) (11 0.47245 0.0 0.0) (210 0.0 0.0 1.0) ) ) (entmake '( (0 . "LWPOLYLINE") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 0) (6 . "ByBlock") (370 . -2) (100 . "AcDbPolyline") (90 . 16) (70 . 129) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 0.47245 0.0) (40 . 0.0) (41 . 0.0) (42 . -0.116132) (91 . 0) (10 0.4951 -0.0065) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 0.7458 -0.1695) (40 . 0.0) (41 . 0.0) (42 . 0.0607686) (91 . 0) (10 0.869 -0.2337) (40 . 0.0) (41 . 0.0) (42 . 0.279764) (91 . 0) (10 0.9038 -0.226) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 0.9378 -0.1977) (40 . 0.0) (41 . 0.0) (42 . 0.167269) (91 . 0) (10 0.983 -0.113) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 0.9943 -0.0564) (40 . 0.0) (41 . 0.0) (42 . 0.0504035) (91 . 0) (10 1.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0504035) (91 . 0) (10 0.9943 0.0564) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 0.983 0.113) (40 . 0.0) (41 . 0.0) (42 . 0.167269) (91 . 0) (10 0.9378 0.1977) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 0.9038 0.226) (40 . 0.0) (41 . 0.0) (42 . 0.279764) (91 . 0) (10 0.869 0.2337) (40 . 0.0) (41 . 0.0) (42 . 0.0607686) (91 . 0) (10 0.7458 0.1695) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 0.4951 0.0065) (40 . 0.0) (41 . 0.0) (42 . -0.116132) (91 . 0) (210 0.0 0.0 1.0) ) ) (entmake '( (0 . "ENDBLK") (8 . "0") (62 . 0) (6 . "ByBlock") (370 . -2) ) ) ) )
Is the TICK.dwg, but I have moved the insertion point and the rotation (180°) and parameter is fixed at "ByBlock"
Hi
can you rotate the block to 180° and move the insertion point.
the insertion point should be on top that's why i want it to be like this.
problem solved already
just change the value of those highlighted in red
(cond
((< det_or 0.0) (setq ang_dir (- (/ (* 3 pi) 2 ))))
((> det_or 0.0) (setq ang_dir (/ (* 3 pi) 2 )))
(progn
(entmake
(0 . "BLOCK")
(8 . "0")
(2 . "TICK")
(70 . 2)
(62 . 0)
(6 . "ByBlock")
(370 . -2)
(10 1.0 0.0 0.0)
