Hi All,
We've recently converted all our microstation drawings to autocad now that the company has decided to go with one cad program company wide.
One of the issues we are having after getting the drawings back from the this co. converting them is the cells to blocks convertion inside the drawing.
when we open a drawing and see a "Fuse" block for instance and if it a has multiple inserts, it named them:
Fuse
Fuse_1
Fuse_2 etc....
is there a lisp routine or some command that would replace the "Fuse_*" blocks with "Fuse"
I've been searching the forums and know about the express tool Replace Block but need to be able to automate somehow.
I thought about trying to rename each of the "Fuse_*" but of course it won't let you rename to a block name that already exists...thanks in advance for any help!!
I developed a routine a few years ago that swaps blockname for \path\newblockname.
Basicly, has a text based 'table' of oldblockname newblockname #attributes rotate Y/N.
Reads that table for each drawing, selects all 'Inserts', gets their name. IF the name is on the list, removes
the old block, inserts replacement block in same insertion point, at same scale factor, and rotation.
I use it to replace IEC controls components with ANSI or visa/versa. It needs to be 'tuned' to a particular 'set'
of drawings, but does a decent job of swapping them out. After swapping in the new block, it purges Blocks.
So, the resultant drawing just has a 'clean' set of blocks (if built correctly).
I'll share / configure the routine if you like. E-Mail: ec-cad@centurytel(dot)net
'remove the dot, replace with .
Bob
EC-CAD
