Visual LISP, AutoLISP and General Customization
Batch Plot with a lisp
5 REPLIES 5
jb4pres
839 Views, 5 Replies
Good afternoon ...
I have about 50 drawings that I need to plot to D size and B size and would love to automate it. The drawback though is I have to run a lisp that changes the draw order otherwise it won't print right.
Has someone written a lisp that:
* Opens a file
* runs lisp (Plot command is the last part of this)
* Closes file
* Opens next file (files have numeric suffix but not every number ... 1000, 1002, 3, 4, 6)
Thanks!!
Eric
5 REPLIES 5
M_Hensley
in reply to: jb4pres
You need to write a script file that will open each file and load the lisp. You may be able to get free ScriptPro to work.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=4091678&linkID=9240618
cadtown
I had some success with batchrun utility years ago and hopefully it is still good and you can make some good use of it. You can download it from:
http://www.cadtown.com
jb4pres
Sorry for the delay in getting back ... I have been fighting scriptpro. It stalls when it hits the lisp.
M_Hensley
Test your lisp by manually loading it in a single drawing to make sure it plots properly without an error message or asking for additional input.
jb4pres
Works flawlessly. Its as if its not even loaded when run via script. I have a bunch of stuff in it that I use regularly so I know acad.lsp loads and works.
”Boost
