Batch Plot with a lisp
5 REPLIES 5
844 Views, 5 Replies
Good afternoon ...
I have about 50 drawings that I need to plot to D size and B size and would love to automate it. The drawback though is I have to run a lisp that changes the draw order otherwise it won't print right.
Has someone written a lisp that:
* Opens a file
* runs lisp (Plot command is the last part of this)
* Closes file
* Opens next file (files have numeric suffix but not every number ... 1000, 1002, 3, 4, 6)
Thanks!!
Eric
5 REPLIES 5
M_Hensley
You need to write a script file that will open each file and load the lisp. You may be able to get free ScriptPro to work.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=4091678&linkID=9240618
cadtown
I had some success with batchrun utility years ago and hopefully it is still good and you can make some good use of it. You can download it from:
http://www.cadtown.com
Sorry for the delay in getting back ... I have been fighting scriptpro. It stalls when it hits the lisp.
M_Hensley
Test your lisp by manually loading it in a single drawing to make sure it plots properly without an error message or asking for additional input.
Works flawlessly. Its as if its not even loaded when run via script. I have a bunch of stuff in it that I use regularly so I know acad.lsp loads and works.
”Boost
