Visual LISP, AutoLISP and General Customization
Batch DXF out routine
7 REPLIES 7
Message 1 of 8
Mr.Hella
2115 Views, 7 Replies
Does anyone in the group know of a routine that is available to "Batch DXF out" a group of dwgs. at once rather than having to do them individually?
Thank you
M.
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
in reply to: Mr.Hella
what product (and version) do you work with? E.g. with Civil3D you can use command _AECCCIVILBATCHCONVERTER that let you do what you are looking for!
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 8
Mr.Hella
in reply to: Alfred.NESWADBA
I'm using plain vanilla Autocad 2012.
Message 4 of 8
pbejse
Thank you
M.
Use Vla-saveas method via script or ODBX
ac2000_dxf
AutoCAD 2000 DXF (*.dxf)
ac2000_Template
AutoCAD 2000 Drawing Template File (*.dwt)
ac2004_dwg
AutoCAD 2004 DWG (*.dwg)
ac2004_dxf
AutoCAD 2004 DXF (*.dxf)
ac2004_Template
AutoCAD 2004 Drawing Template File (*.dwt)
ac2007_dwg
AutoCAD 2007 DWG (*.dwg)
ac2007_dxf
AutoCAD 2007 DXF (*.dxf)
Message 5 of 8
trevor.bird.au
I've attached a program that I hope helps you.
I had to name it BatchDXF-vlx.txt so that it could be posted.
Rename it to BatchDXF.vlx and the command to run it is BATCHDXF.
Trevor
Message 6 of 8
Mr.Hella
Thank you very much for the help. I'll give it a try.
Message 7 of 8
Mr.Hella
Trevor,
Thank you very much for offering this program. It looks exactly like what I was looking for.The questions I have are coming from a person that knows nothing of Visual Lisp so forgive me in advance!!!
I tried putting this routine in my "Startup Suite" & for some reason it doesn't load automatically. Is this normal?! Also, the brouse buttons appear to not function until I paste a directory path into the highlighted fields first, then they function.
Would I have to tweek this routine to work locally automatically with my fille structure.
Thanks again,
Mark
Message 8 of 8
trevor.bird.au
Hi Mark,
Please find attached an updated version.
Rename it to BatchDXF.vlx to use.
My apologies, I had a few things set for testing which I did not change or remove before posting originally.
The browse buttons should work correctly now.
File structure should not be a problem, you can select any source drawings folder and any target folder location.
The program does depend on the AutoCAD Express Tools being installed because it uses a function called "acet-ui-pickdir" which is provided by the Express Tools.
I am not sure why it did not load when using the Startup Suite, I tried it myself and it seemed to go to plan.
Please let me know how you go with this one.
Thanks.
Trevor
”Boost
