Visual LISP, AutoLISP and General Customization
Batch Block insertion
3 REPLIES 3
imtaha
581 Views, 3 Replies
I have more than 100 dwgs, I need to insert a date block on each one of them, can any one help me with a batch file and a lisp routine for that.
Your help will be really apprecaited.
3 REPLIES 3
southie
in reply to: imtaha
Place all your drawings in a folder. Copy the code below to note pad and save in same folder as drawings. Place the block you want to insert in another folder. Launch one of the drawings the at command prompt type; (load "thenameoflispfile") see ;;********* below
(setq plist (vl-directory-files (getvar "dwgprefix") "*.dwg" 1))
(foreach ins1 plist
(setvar "lispinit" 0)
(command "open" ins1)
(command "insert" "c:\\bin\\ws001" "0,0" "" "" "");;***** "c:\\bin\\ws001" your block name with path
(command "save" ins1)
);foreach
(setq plist nil)
HTH
Southie
bitdraughty
in reply to: southie
Hi Southie
Im just trying to get your lisp to work but i am having a couple of problems, can you just explain what the stars are in the name please where you indicate to see below?
thank you
devitg
in reply to: bitdraughty
any thing after a ; it is a comment , it serve as a tip to help the user. In this case, it tell the user to put the whole path and file name, include its extension all further the ; do not do any to the lisp.
”Boost
