1. Context:
We started a project which is going through several scale types (1/100; 1/200; 1/20; 1/5; etc).
We use intensively XREF, and we've done a mistake - we used specific .lin for each drawing scale.
Instead of performing and instructing everyone to use a single template, with a single .lin scale.
AutoCAD 2007, 2008 SP1
2. This causes:
Main File
Xref1| --50_DASHED
Xref2| --100_DASHED
Xref3| -- 200_DASHED
3. Requirement
We want to override or rename all linetypes to a standard linetype name (--100_linetype).
Apllied to all files in several directories.
Just like the Autodesk "Scale List Cleanup Utility" is able to perform (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11062617&linkID=9240617).
i.e.
--50_DASHED to --100_DASHED
--200_DASHED to --100_DASHED
and so on...
4. I've searched and anything doesn't seem to work:
4.1. CAD Standards, but doesn't seem to work
4.2. Script Pro from http://cadecorner.blogspot.com/2006/08/layer-translator.html
4.3. Swap Lisp from http://discussion.autodesk.com/forums/thread.jspa?messageID=6161210�.
This last one looked promising but didn't do anything.
4.4. Other Lisps packages...
5. Please note, i'm newbie at lisps...
6. Is it possible?
Rename, Swap, Translate? I'm lost!!!
I only want "my linetype 50,20,10, etc" to transform to "my linetype"
Is it possible to make it as a filter? like using "*" i.e. *--20_ or *--50_
Thank Your very much!
I hope i wasn't messy.
