Visual LISP, AutoLISP and General Customization
Automatic Numbering that starts at 001
16 REPLIES 16
Message 1 of 17
tsbrown
4668 Views, 16 Replies
Looking for a lisp that will increment the number by 1, but I need it to start at 001
16 REPLIES 16
Message 2 of 17
Kent1Cooper
in reply to: tsbrown
You could use any kind of incrementing, keeping the integer as a numerical value, and with the result each time, apply something like this:
(setq numtext (itoa YourIncrementedNumber))
(while (< (strlen numtext) 3)
  (setq numtext (strcat "0" numtext))
); while
That should force all to three digits, adding as many zeros to the front as needed to get there.
Kent Cooper, AIA
Message 3 of 17
pkenewell6347
Hi tsbrown,
Assuming you have to increment only Integers you will have to follow the sequence:
1) Start with String "001"
2) Convert string to an Integer using (atoi) function
3) add 1 to integer
4) convert the integer back to a string with (itoa) and pad with zeros.
Below is a simple function for padding a string with zeros:
;; Function pads a string representing an integer with zeros
;; Example: (pjk-leadzeros 3 "2") returns "002"
;;                 (pjk-leadzeros 3 "11") returns "011"
(defun pjk-leadzeros (dig str)
 (if (and dig str
             (= (type dig) 'INT)
             (= (type str) 'STR)
             (> dig 0)
  (repeat (- dig (strlen str))(setq str (strcat "0" str)))
 str
Phil
Message 4 of 17
3wood
One of the methods is using attached ALTEXT.vlx, copying 001 to new places, then drawing a polyline representing the path. With "Along paths" option in "Sort selection", you can change all numbers in a sequence quickly.
Message 5 of 17
alanjt_
in reply to: 3wood
Recursion example:
(defun _leadingZero (str num)
  (if (< (strlen str) num)
    (_leadingZero (strcat "0" str) num)
    str
Message 6 of 17
smaher12
in reply to: alanjt_
You can try this. I'm sure there is a better way. I would love to see another point of view...
(defun c:tmp ()
  (setvar 'CMDECHO 0)
  (setq pt# (getint "\nEnter start number: "))
  (setq pt (getpoint "\nSelect point: " ))
   (while pt
	(setq pt#t (strcat "00" (rtos pt# 2 0)))
	(if (> pt# 9)
	  (setq pt#t (strcat "0" (rtos pt# 2 0)))
	(if (/= pt nil)(prnt))
	(setq pt (getpoint "\nSelect point: "))
	(setq pt# (1+ pt#))
   ) ;end while
 (princ)
(defun prnt ()
  (entmake
    (list
      '(0 . "MTEXT")
      '(100 . "AcDbEntity")
      '(100 . "AcDbMText")
      '(8 . "S-ANNO-TEXT")  ;layer
      '(7 . "Standard")
      '(71 . 5)             ;justify
      '(72 . 5)
      '(73 . 1)
       (cons 10 pt)        ;insert point
      '(50 . 0)             ;angle
      '(40 . 10)            ;size
      '(41 . 0.0)           ;textbox width
       (cons 1 pt#t)
    );list
  );entmake
 (princ)
Message 7 of 17
tsbrown
in reply to: smaher12
Thanks for all the help
I'll try these out later today
Message 8 of 17
smaher12
Using Kent1Copper's suggestion this should work if you don't get into the hundreds. Thanks Kent1Copper, as I just learned a little somthing about "strlen" today. This is also a little shorter than my previous post. Enjoy...
(defun c:tmp ()
  (setq num (getint "\nEnter number: "))
  (while
    (setq numtxt (strcat "0" (itoa num)))
      (while (< (strlen numtxt) 3)
	(setq numtxt (strcat "0" numtxt))
      ); while
    (if (/= pt nil)
      (progn
	(entmake
	  (list
	    '(0 . "MTEXT")
	    '(7 . "Standard")
	    '(71 . 5)             ;justify
	    '(72 . 5)
	    '(73 . 1)
	    '(50 . 0)             ;angle
	    '(40 . 10)            ;size
	     (cons 1 numtxt)
	  );list
	);entmake
      );progn
    );if
    (setq num (1+ num))
  );while
 (princ)
Message 9 of 17
_gile
You can also use the Increment application available on Exchange Apps which can do what you want and much more...
Gilles Chanteau
GileCAD
GitHub
Message 10 of 17
gilbertomejiac
Message 11 of 17
gilbertomejiac
Message 12 of 17
tsbrown
Can this be done if you want to used it on existing text?
Message 13 of 17
smaher12
If you want something that works with existing text, check out Message 14 on http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Difficulties-getting-insert-point-for...
With a little tweeking you should be able to get it to do what you want.
Message 14 of 17
smaher12
Give this a shot
(defun c:test (/ txttmp no# ss obj)
  (vl-load-com)
  (initget 1)
 (setq no# (getint "\nEnter number: ")
  ); setq
  (setvar "errno" 0)
  (while
    (while
      (and
	(/= (getvar "errno") 52) (not ss)
      ); and
       (setq ss (ssget "+.:S" '((0 . "*TEXT"))))
    ); while
     (setq obj (vlax-ename->vla-object (ssname ss 0))
           no#t (strcat "0" (itoa no#))
     ); set
      (while (< (strlen no#t) 3)
	(setq no#t (strcat "0" no#t))
      ); while
     (vlax-put obj 'textstring no#t)
     (vlax-release-object obj)
     (setq no# (1+ no#)
	   ss  nil
     ); set
     (setvar "errno" 0)
  ); while
Message 15 of 17
pbejse
Yey another  one.
(defun _pad0 (str ln zn)
  (setvar 'dimzin 4)
  (setq str (strcat (substr (rtos (* 0.0) 2 (- ln (Strlen str))) 2) str))
  (setvar 'dimzin zn)
  str
_$ (_pad0 "1" 2 (getvar 'dimzin))
"01"
_$ (_pad0 "1" 3 (getvar 'dimzin))
"001"
_$ (_pad0 "1" 4 (getvar 'dimzin))
"0001"
_$ (_pad0 "100" 4 (getvar 'dimzin))
"0100"
Message 16 of 17
Kent1Cooper
@smaher12 wrote:
Using Kent1Copper's suggestion this should work if you don't get into the hundreds. ....
(defun c:tmp ()
  (while
    (setq numtxt (strcat "0" (itoa num)))      (while (< (strlen numtxt) 3)
      ); while
If you change the red line above, to just:
(setq numtxt (itoa num))
it actually will work into the hundreds, and in fact, into the thousands and beyond.  The (while) function simply won't do anything if it's already 3 [or more] digits.  The "0" you're adding with the red line will be added by the first pass through the (while) loop, but only if needed.
[EDIT:  For some unknown reason, the system moved the first line of the (while) function up to a continuation of the red line.  I tried putting it back where it was, but somehow it didn't take.  Replace only the red part, not that whole line as it shows above.]
Kent Cooper, AIA
Message 17 of 17
tsbrown
Thanks again for all the help
”Boost
