The demo I d/l'd didn't have a spanner.lsp file in it. I'm assuming this is
a custom file you created. Can you post the code so that we can see what's
going on?
From your description it should just be doing something like this:
(load "span12.lsp")
(c:sheetall)
You can't use (command "sheetall") because isn't not a real command you have
to call it like a lisp function just like any other C: function defined in
lisp. This is true for even R14, R13, R12 or any and all versions of
AutoCAD to date 😉
Kevin Nehls
"kheinz" wrote in message
news:f169153.1@WebX.maYIadrTaRb...
> I have the Appload loading a Spanner.lsp file upon startup. This in return
tells AutoCAD 2002 to load the span12.lsp and then run the Sheetall command.
When each drawing loads it is supposed to look and see if a spanner sheet
needs to be updated by the use of the sheetall command. It used to work in
AutoCAD R14, but will not run the Sheetall command. It comes up and error
"Unknown command SHEETALL". Any ideas?
> Ken@rlmrlm.com
