Yeah - I decided on the block insertion method right after I posted. I then
ssget it, erase, then purge it. 'Not pretty, but it works...below is the
line in the menu, (it calls a script for actually running the mline at the
end):
^C^C-insert;mlrw.dwg;0,0;;;;(ssget "x" '((2 .
"mlrw")) );erase;p;;-purge;B;mlrw;n;script;RWall8.SCR
John
"David Kozina" wrote in message
news:4072dfad$1_3@newsprd01...
> Easiest is probably to define them in /a block/s and insert it.
> voila! (But this is a horrible kludge, IMO)
> MLstyles can be entmake'd, btw, which is what I do now - but I'm looking
for
> ways to do this with activex stuff... :)
> hth,
> David Kozina
> "John Schmidt" wrote in message
> news:4072de1a$1_3@newsprd01...
> > I'm trying to find a way to have some custom multilines get
automatically
> > loaded at startup. They exist in the acad.mln file, but unless loaded
and
> > saved with a drawing or template, cmstyle won't allow specifying them.
> > The reason I want them loaded at startup is that these selections will
be
> > included in a custom menu so the user doesn't always have to open up the
> > multiline dialog box and load/set them each time they're needed. And
since
> > these functions will be used in hundreds of existing drawings, it does
no
> > good to have them loaded into templates, etc.
> > 'Any suggestions on how to load them either through lisp or some other
> way?
> > Thanks for any suggestions!
> > John
