I'm working up a routine to simplify clearing some space. I've been cruising here and other places piecing together something, but what I have ended up with is a routine that deletes all of the intended information (possibly needing repetition for those hard-to-reach blocks), but also deletes dimensions from the model space.
There are several things our company does which are "non-standard" but we have been at it for a while and I am trying to work with what I was given. Following is the code. If anyone has an idea why it would be grabbing dimensions and how I could make it stop, I would appreciate it.
;;; not sure who Jeff M is, but assuming this bit is from him (defun odbx-test (/ dbx_doc) ;; edited 5/28/06 by Jeff M (if (< (setq dbxver (atof (getvar "ACADVER"))) 15.06) (progn (alert "ObjectDBX method not applicable\nin this AutoCAD version" ) (exit) (princ) (gc) ) (progn (if (= (atoi (getvar "ACADVER")) 15) (progn (if (not (vl-registry-read "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument\\CLSID" ) ) (startapp "regsvr32.exe" (strcat "/s \"" (findfile "axdb15.dll") "\"") ) ) (setq dbx_doc (vla-getinterfaceobject (vlax-get-acad-object) "ObjectDBX.AxDbDocument" ) ) ) (setq dbx_doc (vla-getinterfaceobject (vlax-get-acad-object) (strcat "ObjectDBX.AxDbDocument." (itoa (fix dbxver)) ) ) ) ) ) ) ) ;;; Following bit is compiled from a few places. I know it's messy.
;;; I'll clean it after it works and give better credits (defun C:PURGEDIR (/ fileNames fileName_doc fname folderObject i myDoc obj result sh ) (vl-load-com) (setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application" ) ) (setq Dir (vlax-invoke-method sh 'BrowseForFolder 0 "Browse to the directory you want purged." 512 ; no new folder button "C:\\" ; path start ) ) (vlax-release-object sh) (if Dir (progn (setq folderObject (vlax-get-property Dir 'Self) result (vlax-get-property folderObject 'Path) ) (vlax-release-object Dir) (vlax-release-object folderObject) result ) ) (setq fileNames (vl-directory-files result "*.dwg" 1) filenames (mapcar (function (lambda (x) (strcat result "\\" x) ) ) filenames ) ) (foreach fileName fileNames (if (setq fname (findfile fileName)) (progn (setq fileName_doc (odbx-test)) (vla-Open fileName_doc fname) (repeat 2 (foreach i '("Blocks" ;for some reason the dimensions are being deleted with the Blocks "DimStyles" "Linetypes" "Layers" "TextStyles") (vlax-for Obj (vlax-get fileName_doc i) (if (or (not (vlax-property-available-p Obj 'IsLayout)) (= (vla-get-IsLayout Obj) :vlax-false) ) (vl-catch-all-apply 'vla-Delete (list Obj)) ) ) ) ) (vlax-invoke fileName_doc 'SaveAs fname) (vl-catch-all-apply (function (lambda () (vlax-release-object fileName_doc) ) ) ) (princ (strcat "\n" fname " Purged.")) (setq fileName_doc nil) ) (princ "\nFile not found. It may have been moved or modified." ) ) ) (gc) (princ) )
Solved by pbejse. Go to Solution.
@Anonymous wrote:......
or modified."
I cant vouch for the rest of the code
(vlax-for Obj (vlax-get fileName_doc i) (if (and (not (Wcmatch (vla-get-name Obj) "`*D*")) (or (not (vlax-property-available-p Obj 'IsLayout)) (= (vla-get-IsLayout Obj) :vlax-false)) ) (vl-catch-all-apply 'vla-Delete (list Obj)) ) )
HTH
That was the one. Thanks very much. Yes, the rest of the code needs cleaning, but now at least it does not destroy anything unintended. I bet if I make it cycle differently I can get more of the nested blocks cleared, but it will probably take longer.
Either way, this works wonderfully now. I appreciate it.
