Hey everyone,
I've searched and searched and can't find anything to really help me. Keep in mind I'm very new to AutoLISP.
I've been using this code to attempt to renumber my layout tab names. Unfortunately everytime I specify a new starting number (say because we added a new tab) it stacks the new number with the complete old tab name.
(defun c:NUMLAYOUT (/ *error*) (princ "\rNUMLAYLOUT ") (defun *error* (msg) (if acDoc (vla-endundomark acDoc) ) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ) ; Fatal error, display it (princ) ) ((lambda (acDoc / i suffix delin) (vla-startundomark acDoc) (if (and (setq i (1- (getint "\nEnter starting number: "))) (if (/= "" (setq suffix (getvar "ctab")) ) (setq suffix (strcat " " suffix)) ) ) (progn (foreach x (layoutlist) (vla-put-name (vla-item (vla-get-layouts acDoc) x) (strcat (itoa (setq i (1+ i))) suffix) ) ) (*error* nil) ) (*error* "Must enter start of sequence") ) ) (vla-get-activedocument (vlax-get-acad-object)) ) )
I'm looking for help with having (getvar "ctab") to ignore the first 2 or 3 variables when it grabs the name.
Jason (NEWBIE)
Solved by ВeekeeCZ. Go to Solution.
That's a bummer, ran out of time to edit my post.
This is the code I really wanted to add. I'd still like a way to replace the old 2-3 variables on the tab name with the newly imputed "page number".
(defun c:NumberingPages (/ i) (vl-load-com) (setq i (1- (getint "\nEnter starting number: "))) (foreach x (layoutlist) (vla-put-name (vla-item (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)) ) x ) (strcat (itoa (setq i (1+ i))) " " x) ) ) (princ) )
Thanks and sorry about the confusion.
Try... (without seeing your last "edit")
(vl-load-com) (defun c:NUMLAYOUT (/ *error* Layorder) (princ "\rNUMLAYLOUT ") (defun *error* (msg) (if acDoc (vla-endundomark acDoc) ) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ) ; Fatal error, display it (princ) ) (defun Layorder (/ order) ; pbejse https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/layout-order/td-p/3749964 (vlax-for lay (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (setq order (cons (list (vla-get-name lay) (vla-get-taborder lay)) order))) (mapcar 'car (Cdr (vl-sort order '(lambda (j k) (< (cadr j) (cadr k))))))) ((lambda (acDoc / i suffix delin) (vla-startundomark acDoc) (if (and (setq i (1- (getint "\nEnter starting number: "))) (setq suffix (getvar "ctab")) ) (progn ;(if (wcmatch suffix "#* *") (setq suffix (strcat " " (vl-string-left-trim " " (substr suffix (+ 2 (vl-string-position 32 suffix))))))) (if (wcmatch suffix "#* *") (setq suffix (substr suffix (+ 1 (vl-string-position 32 suffix))))) (foreach x (layorder) (vla-put-name (vla-item (vla-get-layouts acDoc) x) (strcat (itoa (setq i (1+ i))) suffix) ) ) (*error* nil) ) (*error* "Must enter start of sequence") ) ) (vla-get-activedocument (vlax-get-acad-object)) ) )
I used pbe's sub for sorting layouts... because (layoutlist) is in the order layouts were created.
Edit: if you're sure that there are always two spaces behind a number.... (see modified version)
pbe's is awesome! Thanks so much for that.
I'm still having an issue with keeping the old tab name and just replacing the numbers.
I've done this now
(defun c:NumberingPages (/ i) (vl-load-com) (defun Layorder (/ order) ; pbejse https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/layout-order/td-p/3749964 (vlax-for lay (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (setq order (cons (list (vla-get-name lay) (vla-get-taborder lay)) order))) (mapcar 'car (Cdr (vl-sort order '(lambda (j k) (< (cadr j) (cadr k))))))) (setq i (1- (getint "\nEnter starting number: "))) (foreach x (layorder) (vla-put-name (vla-item (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)) ) x ) (strcat (itoa (setq i (1+ i))) " " x) ) ) (princ) )
This pbejse worked amazingly on an old drawing I was having trouble with.
hmm... the algorithm is the same as I used in my first post........ marked in red. HTH
(vl-load-com) (defun c:NumberingPages (/ i Layorder) (defun Layorder (/ order) ; pbejse https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/layout-order/td-p/3749964 (vlax-for lay (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (setq order (cons (list (vla-get-name lay) (vla-get-taborder lay)) order))) (mapcar 'car (Cdr (vl-sort order '(lambda (j k) (< (cadr j) (cadr k))))))) (setq i (1- (getint "\nEnter starting number: "))) (foreach x (layorder) (vla-put-name (vla-item (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)) ) x ) (strcat (itoa (setq i (1+ i))) (if (wcmatch x "#* *") (substr x (+ 1 (vl-string-position 32 x))) (strcat " " x))) ) ) (princ) )
Edit: Sorry, fixed. I bet you have done the same, right? 🙂
or
(strcat (itoa (setq i (1+ i))) " " (if (wcmatch x "#* *") (substr x (+ 3 (vl-string-position 32 x))) x))
