306 Kudos
Post 21 of 29
Re: AutoLisp and Fields
10-18-2012 06:29 AM in reply to: pbejse
<Not Tested for newer version>  2010 onwards
(defun c:Oarea (/ Get-ObjectIDx64 space ss pt are sst tm)(vl-load-com)
;;;	Jimmy Bergmark			;;;
;;;	http://blog.jtbworld.com/	;;;
(defun Get-ObjectIDx64 (obj / util)
  (setq util (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object))))
    (if (> (vl-string-search "x64" (getvar "platform")) 0)
      (vlax-invoke-method util "GetObjectIdString" obj :vlax-False)
      (itoa (vla-get-Objectid obj))
;;;		pBe Oct 18 2012		;;;
  (if (and (setq ss (car (entsel "\n Select Object for Area : ")))
	   (vlax-property-available-p (setq ss (vlax-ename->vla-object ss)) 'Area)
	   (setq pt (getpoint "\n Specify Text Location :"))
	(progn
	  (setq are (rtos (* (vla-get-area ss) 0.0001) 2 2)
	        sst (vlax-invoke  (vlax-get (vla-get-ActiveLayout
	                                         'Block)
	                                   'addMText pt 1.
			(strcat	"%<\\AcObjProp Object(%<\\_ObjId "
				(Get-ObjectIDx64 ss)
				">%).Area \\f \"%lu2%pr2%ps[, m²]%ct8[0.0001]\">%")
		tm (textbox (list (cons 1 (strcat (vl-string-translate "1" "0" are) " m²"))
			      (cons 40 (vla-get-height sst))
			      (cons 7 (getvar 'TextStyle)))))
		(vla-put-width sst (distance (Car tm)(list (caadr tm)(cadar tm))))
	  )(princ "\nNo object for Area Text Selected"))
  (princ)
command: Oarea
HTH
0 Kudos
Post 22 of 29
10-18-2012 02:32 PM in reply to: pbejse
For the Arial font does not work only with this value. But if doubling works well.
I changed the code:
by
(vla-put-width sst (* 2(distance (Car tm)(list (caadr tm)(cadar tm)))))
and worked!
I intend in the future to increase. I'll put a "GetString" to capture a name for the room. Also select the name of the layer via a hatch field to define the type of flooring. etc
Valued Contributor
0 Kudos
Post 23 of 29
01-17-2013 02:32 PM in reply to: eddyrichardson
I am working on another project were I need to use a field, but in this case we are showing imperial and metric in the dimension. (with alternate units) the field only shows the primary units. How can I get it to show both? I've tried monkeying around with it a bit using the field expression that shows up when I create the field with no luck.
Is it possible to do this?
angie
0 Kudos
Post 24 of 29
02-13-2013 10:21 AM in reply to: angiegauthier
I'm not sure how.
but you can convert the value using the following calculation:
1 m² = (3.28083989501) ² = 10.7639104167 ft ²
can see that in my case I need to convert from cm  to m² in the following line:
believe you can replicate content writing line area and do the conversion to their units (imperial)
I hope someone more expert can give a more concrete help.
Valued Contributor
0 Kudos
Post 25 of 29
02-14-2013 12:24 PM in reply to: pbejse
...so I cheated a little to make this work.
I drew a line along the edge I was dimensioning. then I had the field reference the length of the line instead of using the measurement. This way I was able to get the units I needed, and if the user stretches the object, the line I drew will stretch along with it and the field will still update. An extra step, but it works.
Angie
New Member
0 Kudos
Post 26 of 29
01-11-2014 05:23 AM in reply to: angiegauthier
This rutine is very good:smileyhappy:
(vl-load-com)
(defun c:Test (/ space ss pt)
  ; Tharwat 14. 06. 2011
  (setq space (vla-get-modelspace
                (vla-get-ActiveDocument (vlax-get-acad-object))
  (if (and (setq ss (car (entsel "\n Select a Dimension : ")))
    (vla-addMText
      space
      (vlax-3d-point pt)
      4.
              (itoa (vla-get-ObjectID (vlax-ename->vla-object ss)))
              ">%).Measurement \\f \"%lu6\">%"
    (princ)
  (princ)
Can you help me how can write the mtext with text height 50? And after I need to explode it to convert for normal text.
Thank you!!!!!!!!
New Member
0 Kudos
Post 27 of 29
10-10-2014 06:39 AM in reply to: abaluuuu
Thank you about the rutine display above, it returns with Mtext
is it possible to obtain text version of it?
thank you again.
Active Contributor
0 Kudos
Post 28 of 29
10-11-2014 11:43 AM in reply to: korayozal
Just curious has anyone been able to do the reverse of a field? Find the object that field if refering to? Example, if have text thats value is the contents of another text entity. How can i find where the refernce is coming from?
Leland
Civil3d 2012
Windows 7 64x (16 gigs ram)
542 Kudos
Post 29 of 29
10-11-2014 02:15 PM in reply to: lelandleahy4987
Hi Leland,
one way at go.lsp by jdvillarreal...
Hope that helps
Henrique
