putitonpaper
Message 11 of 26 (702 Views)
Re: AutoLisp and Fields
11-17-2011 03:43 AM in reply to: angiegauthier
Can Lisp, or another method, be used to modify Fields in Sheetset etc. I'd like to modify or update dates, text, and revision fields within several large drawing packages which use Sheetsets, is this possible, what would be the best tool / method to use?
Thanks ! ! !
Gustavo_Bernardi
Message 12 of 26 (640 Views)
10-03-2012 07:32 AM in reply to: putitonpaper
why is not working?
(vl-load-com)
(defun c:Test (/ space ss pt)
; Tharwat 14. 06. 2011
(setq space (vla-get-modelspace
(vla-get-ActiveDocument (vlax-get-acad-object))
(if (and (setq ss (car (entsel "\n Select a Dimension : ")))
(setq pt (getpoint "\n Specify Text Location :"))
(vla-addMText
space
(vlax-3d-point pt)
4.
(strcat "%<\\AcObjProp Object(%<\\_ObjId "
(itoa (vla-get-ObjectID (vlax-ename->vla-object ss)))
">%)Area \f "%lu2%pr2%ps[, m²]%ct8[0.0001]">%"
(princ)
(princ)
Thanks!
Active Member
kakt00z
Message 13 of 26 (609 Views)
10-08-2012 12:24 AM in reply to: Gustavo_Bernardi
may be u need to add slash before quotes
something liske that :
"%<\AcObjProp Object(%<\_ObjId "
">%).Area \f \"%lu2\">%
pbejse
Message 14 of 26 (597 Views)
10-08-2012 03:04 AM in reply to: Gustavo_Bernardi
Gustavo_Bernardi wrote:
why is not working?
Thanks!
(strcat
  "%<\\AcObjProp.16.2 Object(%<\\_ObjId "
  ">%).Area \\f \"%lu2%pr2%ps[,m²]\">%"
HTH
Gustavo_Bernardi
Message 15 of 26 (561 Views)
10-09-2012 03:35 PM in reply to: putitonpaper
nothing yet ...
I need to measure the area that is in centimeters and put text in square meters. It would be great if you could put the unit at the end of the text (m2).
Thanks for now
pbejse
Message 16 of 26 (557 Views)
10-09-2012 05:59 PM in reply to: Gustavo_Bernardi
nothing yet ...
Thanks for now
Nothing happens? no prompt for text location or no text at all? whats the error?
sq centimeters to sq meters -- > 15000 = 1.5 ?
64 bit OS?
It would help if you'll give us more info.
Gustavo_Bernardi
Message 17 of 26 (535 Views)
10-12-2012 09:24 PM in reply to: putitonpaper
Hi, yes my OS is 64-bit.
The object selection is no problem, the base point is then asked me the error that appears is this:
"Specify Text Location:, error: bad argument type: nil stringp"
What I did was take the code at the beginning of this topic. So I changed that part of the field by code provided by window creation field with my desired properties.
Yes, what I need is a measure of area with the value 15000 return me the value 1.5
Thanks for your patience
The code works for you?
(vl-load-com)
(vla-addMText
space
(vlax-3d-point pt)
4.
(princ)
(princ)
pbejse
Message 18 of 26 (530 Views)
10-12-2012 10:09 PM in reply to: Gustavo_Bernardi
Try the attached file
Gustavo_Bernardi
Message 19 of 26 (498 Views)
10-17-2012 06:18 AM in reply to: pbejse
The field works well ... thank you
Just wish I could control the width of the text box so that the symbol is not in the second row.
In another lisp that I created, I used the code STRLEN to get the text length (in letters) and multiply by an average width.
I still have to study these VL-something ... I do not understand any of this, I create my lisps only with get--- and command
Thank you for your attention
pbejse
Message 20 of 26 (488 Views)
10-17-2012 08:44 AM in reply to: Gustavo_Bernardi
You are welcome, I will look into that width thingy tommorrow.
Cheers
