I have a user who, somehow, managed to uninstall Autodesk 360 and now a lot of the customization routines (mostly involving ActiveX and Visual Lisp) that I wrote won't run on his computer. How do I restore the program on his computer from a network deployment?
Thank you,
J Edward Leavitt
I'm sorry, I forgot to post the error code:
error: ActiveX Server returned an error: Error loading type library/DLL
Maybe instead of reinstalling Autodesk 360, you can simply re-register the COM DLLs that you need to load. Use RegSvr32 /i <dll-path> at the SHELL command prompt to register the DLL that implements the COM type library or object you're having trouble with and see if it resolves the problem.
