Autodesk 360 is missing
2 REPLIES 2
JEdwardL
293 Views, 2 Replies
I have a user who, somehow, managed to uninstall Autodesk 360 and now a lot of the customization routines (mostly involving ActiveX and Visual Lisp) that I wrote won't run on his computer.  How do I restore the program on his computer from a network deployment?
Thank you,
J Edward Leavitt
2 REPLIES 2
JEdwardL
in reply to: JEdwardL
I'm sorry, I forgot to post the error code:
     error: ActiveX Server returned an error: Error loading type library/DLL
owenwengerd
Maybe instead of reinstalling Autodesk 360, you can simply re-register the COM DLLs that you need to load. Use RegSvr32 /i <dll-path> at the SHELL command prompt to register the DLL that implements the COM type library or object you're having trouble with and see if it resolves the problem.
Owen Wengerd
ManuSoft
”Boost
