Visual LISP, AutoLISP and General Customization
Autocad's default Save file location
2 REPLIES 2
almeida.4
19431 Views, 2 Replies
I would like to change Autocad 2010 default file location. When I go to Tools->Files it only gives me the option to change the file to the temporary folder. However, I want to be able to save my actual projects to a different folder.
How could I do that?
Thank you,
EFA
2 REPLIES 2
Kent1Cooper
in reply to: almeida.4
I don't have 2010, but if it works like earlier versions, try this:
Right-click on the desktop or Start-menu icon that starts AutoCAD, and pick Properties.  Put the location you want in the "Start in:" slot.  Then if you open it from that icon, when you first go to Save a new drawing, that's the folder it will default to.
Kent Cooper, AIA
southie
Another way
Double-click a drawing in Windows Explorer to launch AutoCAD® and open the drawing.
Set System Variable: REMEMBERFOLDERS to 0
Controls the default path displayed in standard file selection dialog boxes.
0
Uses standard Microsoft behavior. When you first start the program after installation, the default path in each standard file selection dialog box is My Documents. When you open or save a file to another folder, that folder is remembered for future file selection. The Start In folder specified for the shortcut icon is not used)
1
Restores the behavior of AutoCAD 2000 and previous releases. When you start the program by double-clicking a shortcut icon, if a Start In path is specified in the icon properties, that path is used as the default for all standard file selection dialog boxes.
”Boost
