I would like to change Autocad 2010 default file location. When I go to Tools->Files it only gives me the option to change the file to the temporary folder. However, I want to be able to save my actual projects to a different folder.
How could I do that?
Thank you,
EFA
@almeida.4 wrote:....
I don't have 2010, but if it works like earlier versions, try this:
Right-click on the desktop or Start-menu icon that starts AutoCAD, and pick Properties. Put the location you want in the "Start in:" slot. Then if you open it from that icon, when you first go to Save a new drawing, that's the folder it will default to.
Another way
Double-click a drawing in Windows Explorer to launch AutoCAD® and open the drawing.
Set System Variable: REMEMBERFOLDERS to 0
Controls the default path displayed in standard file selection dialog boxes.
