I can run the ACC fine on multiple DWG files with a basic set of commands in the script file. But, when I try to load an AutoLISP/Visual LISP file and run it from inside the script file, it doesn't work. Does anyone know how to run a LISP file using the ACC?
Randy
Solved by rpearsall. Go to Solution.
Augusto Gonzalves from Autodesk answered my question / solved the problem.
Visual Lisp (ActiveX) commands DO NOT WORK with AutoCAD Core Console at this time. Only straight AutoLISP commands work. Anything with a VL prefix does not work.
