Visual LISP, AutoLISP and General Customization
auto lisp
25 REPLIES 25
Message 1 of 26
kishku
1000 Views, 25 Replies
auto lisp
hii friends,
 Anybody have autolisp programme for creating  text coordinates for blocks. attribute not required. creating text of x and y value as text in autocad file itself not any excel files etc, or anybody have idea to create it
25 REPLIES 25
Message 2 of 26
pbejse
in reply to: kishku
Obtaining the coordinates is not that hard, the question is:
The return string value
  • TEXT or MTEXT?
  • TextStyle?
  • TextHeight?
  • Layer?
  • Annotattive?
  • Use Tables?
  • Units?
  • String Format?
X=51.00
Y=12.36
or
51.00,12.36
or
(51.00 12.36)
Message 3 of 26
_Tharwat
in reply to: kishku
You may mean this ..... Smiley Wink
   (defun c:TesT (/ ss p)
  (if (and (setq ss (ssget "_:L" '((0 . "INSERT"))))
           (setq p (getpoint "\n Specify Coordinates Texts Location :"))
    ((lambda (i / e pt)
       (while
         (setq e (entget (ssname ss (setq i (1+ i)))))
          (setq pt (cdr (assoc 10 e)))
          (entmakex
            (list
              (cons 0 "TEXT")
              '(100 . "AcDbEntity")
              '(100 . "AcDbText")
              (cons 10 p)
              (cons 40
                    (if (eq 0.0 (cdr (assoc 40 sty)))
                      (setq hgt
                             (cdr (assoc 42
                                         (setq sty (entget (tblobjname
                                                             "Style"
                                                             (getvar 'textstyle)
              (cons 1 (strcat (rtos (car pt) 2) "," (rtos (cadr pt) 2)))
          (setq p (list (car p) (- (cadr p) (* hgt 1.5))))
      -1
    (princ)
  (princ)
Message 4 of 26
kishku
in reply to: pbejse
 hi
i need this format with text or mtext
N 51.00
E 12.36
Message 5 of 26
_Tharwat
in reply to: kishku
Here it goes ....
    ((lambda (i / e pt)
       (while
          (entmakex
            (list
              (cons 0 "TEXT")
              '(100 . "AcDbText")
              (cons 10 p)
              (cons 40 (setq hgt (getvar 'textsize)))
              (cons 1 (strcat "N" (rtos (car pt) 2 2) "," "E" (rtos (cadr pt) 2 2)))
      -1
    (princ)
  (princ)
Message 6 of 26
Kent1Cooper
in reply to: kishku
In addition to the important questions pbejse raises, I would add:
One at a time, or multiple Blocks?
If multiple, do it for all Blocks, or all Blocks of a certain name, or a User selection, or...?
Position of Text: User selection, or some fixed relationship to each Block, or a list somewhere separate from the Blocks themselves, or...?
Answering the various questions would confirm or negate some of the choices Autolisper made in their suggested routine.
Also, you would be more likely to catch the attention of people who can answer your question if your Subject line were actually about what you're looking for.  Probably 95%, maybe more, of all threads here are about AutoLISP in one way or another....  See:
http://catb.org/~esr/faqs/smart-questions.html
Kent Cooper, AIA
Message 7 of 26
Kent1Cooper
in reply to: kishku
N 51.00
E 12.36
Try putting something like
+northing +easting +block
into the Search window -- you may find something that already does what you want.
Kent Cooper, AIA
Message 8 of 26
kishku
in reply to: kishku
hi  thanks for ur reply
 i can't acesses to your link
Message 9 of 26
_Tharwat
in reply to: kishku
can you please be more specific with your replies kishku
Message 10 of 26
kishku
in reply to: _Tharwat
hi friends
 i"m attaching a sample drawing . In the drawing  i have created coordinate for one block , like that i have to create coordinates for other blocks . like that  ihave to create coordinate for 100 or 200 blocks in one drawing , if I write manually it will take too much time. this all blocks are in one layer. if i can control the text size it is good. and also i'm new to this autolisp programmes so please help me
Message 11 of 26
Kent1Cooper
in reply to: kishku
Since I think the only link is mine in Message 6....  That website seems to be down temporarily [it was working this morning].  Try again later, or here's another site with what looks like the same document:
http://linuxmafia.com/faq/Essays/smart-questions.html
Kent Cooper, AIA
Message 12 of 26
Kent1Cooper
in reply to: kishku
@kishku wrote:
.... i"m attaching a sample drawing . In the drawing  i have created coordinate for one block , like that i have to create coordinates for other blocks....
Here's something that will do that, in simplest terms.  It doesn't have any of the usual enhancements [error handling, turning CMDECHO off, Layer control, etc.], but it seems to work.  It does it pretty much like your example, except that I regularized the vertical positions of the text.  It adds the text to all such Blocks in a drawing, but could be altered to do it for only a User selection of them.  And it could ask the User for a Block name instead of working with only the built-in name, etc., etc.
(defun C:MarkNEblk (/ blkss inspt)
  (setvar 'textstyle "STANDARD")
  (setvar 'textsize 1)
  (setq blkss (ssget "_X" '((2 . "blk"))))
  (repeat (sslength blkss)
    (setq inspt (cdr (assoc 10 (entget (ssname blkss 0)))))
    (command
      "_.text"
      "_none" (mapcar '+ inspt '(2 0.3 0))
      (strcat "N " (rtos (cadr inspt) 2 4))
      "_.text"
      "_none" (mapcar '+ inspt '(2 -1.3 0))
      (strcat "E " (rtos (car inspt) 2 4))
    ); end command
    (ssdel (ssname blkss 0) blkss)
  ); end repeat
); end defun
Kent Cooper, AIA
Message 13 of 26
_Tharwat
in reply to: Kent1Cooper
Mr Kent .
The ssget needs Type of entity to search for into your code .
(setq blkss (ssget "_X" '((0 . "INSERT")(2 . "blk"))))
I could not understand the OP request to give him the right codes, anyway nice codes .
Regards.
Message 14 of 26
kishku
Dear kent and autolisper thanks for your reply. i tried it but failed. i'm new to autolisp can you send me autolisp file and procedure  thanks to both
Message 15 of 26
pbejse
in reply to: kishku
Check your block name against the code
(setq blkss (ssget "_X" '((2 . "blk"))));<----- check this
BTW are there any taget blocks on layout tab?
Message 16 of 26
kishku
in reply to: pbejse
here i'm attaching one more sample  block name will change every time. In this sample i have moved some text that is overlapping
Message 17 of 26
pbejse
in reply to: kishku
try this
(defun C:MarkNEblk (/ blknme blkss inspt)
(if	(and
  	(setq blknme (car (entsel "\nSelect Block to label:")))
  	(if blknme
          	(eq (cdr (assoc 0 (setq blknme (entget blknme)))) "INSERT")))
  (progn  (setvar 'textstyle "STANDARD")
  (setvar 'textsize 100)
  (setq blkss (ssget "_X" (list '(0 . "INSERT") (cons 2 (cdr (assoc 2 blknme))))))
    (command
      "_.text"
      "_none" (mapcar '+ inspt '(100 100.0 0))
      "_.text"
      "_none" (mapcar '+ inspt '(100 -60.0 0))
    ); end command
  ); end repeat
	(princ "\nNo Block selected")
  (princ)
That is what concern all along. (TEXT properties)
If your drawing will always be this scale, you can leave the code as it is. but
For favorable results, what we can do is prompt you for text height and block name, and everything will follow
 EDIT: Add prompt for block name selection
Message 18 of 26
_Tharwat
in reply to: kishku
Check this out Buddy .
  (if (setq ss (ssget "_X" '((0 . "INSERT")(2 . "BLOCK"))))
     ((lambda (i / e pt)
       (while
          (entmakex
            (list
              (cons 0 "MTEXT")
              '(100 . "AcDbMText")
              (cons 10 pt)
              '(40 . 70.0)
              (cons 1 (strcat "N" (rtos (car pt) 2 2) "\n" "E" (rtos (cadr pt) 2 2)))
      -1
    (princ)
  (princ)
Message 19 of 26
pbejse
to avoid error your code
     ((lambda (i / e pt)
       (while
         (setq e (ssname ss (setq i (1+ i))))
          (setq pt (cdr (assoc 10 (entget e))))          (entmakex
            (list
              (cons 0 "MTEXT")
              (cons 10 pt)
              '(40 . 70.0)
      -1
    (princ)
  (princ)
Message 20 of 26
_Tharwat
in reply to: pbejse
Thank you.
I do agree with but in some cases not all .Smiley Wink
Please check this double construction of the same value in yours .
equal to
(assoc 2 blknme)
It's already discussed in Cadt......
Best regards,
”Boost
