Visual LISP, AutoLISP and General Customization
Attributes inside Xref to mleader
7 REPLIES 7
Message 1 of 8
JCprog
411 Views, 7 Replies
Hello everyone! Smiley Happy
Found this lisp in the forums by Jim Claypool which grabs attributes from a block within xrefs. Works nicely but I need to only choose some specific tags (tag01, tag02, tag03) and write the attribute value to mleader. Please help! Thanks in advance and Happy Thanksgiving to everyone!!!!!Smiley LOL
(defun c:xrefatts ()
(setq ename (nentsel "\nSelect block in XREF: "))
(if (= (length (nth 3 ename)) 2)
(progn
(setq attlist
(setq obj (vlax-ename->vla-object (car (nth 3 ename))))
(mapcar
'(lambda (Att)
(cons (vla-get-TagString Att) (vla-get-TextString Att))
(vlax-invoke Obj "GetAttributes")
;else
(alert "Object selected is not a block")
7 REPLIES 7
Message 2 of 8
hmsilva
in reply to: JCprog
Hi JCprog,
the Jim Claypool's 'xrefatts' return an association list of dotted pairs with  'TAG . value'.
Using Jim Claypool's 'xrefatts', slightly modified, testing for those specific tags and passing the returned to the 'mleader' command, perhaps something like this will do the trick...
(defun c:demo (/ xrefatts att y lst)
  ;; http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extract-attribute-values-from-xref/m-...
  ;; original by Jim Claypool
  ;; modified by me
  (defun xrefatts (/ Att attlist ename Obj)
    (if (setq ename (nentsel "\nSelect block in XREF: "))
        (progn
          (setq attlist
          (mapcar
            '(lambda (Att)
  (if (setq lst (xrefatts))
    (progn
      (foreach x '("tag01" "tag02" "tag03")
        (if (setq y (assoc x lst))
          (progn
            (prompt (strcat "\nStart Mleader for TAG < " (car y) " >: \n"))
            (command "_.mleader" "\\" "\\" (cdr y))
          (prompt "\nAttribute TAG < " x " > was not found! ")
    (prompt "\nSelected object was not a block!")
  (princ)
Hope that helps
Henrique
Message 3 of 8
JCprog
in reply to: hmsilva
Thanks Henrique for the reply. It works well but I was hoping for the tags to be listed in one mleader
e.g.
tag01Value
tag02Value
tag03Value
....and shouldnt matter if attribute is blank.
Message 4 of 8
hmsilva
in reply to: JCprog
You're welcome, JCprog
Try
  ;; modified by me
        (progn
          (setq attlist
          (mapcar
            '(lambda (Att)
    (progn
      (setq txt "")
          (setq txt (strcat txt (car Y) "=" (cdr y) "\\P"))
      (if (/= txt "")
        (command "_.mleader" "\\" "\\" (vl-string-right-trim "\\P" txt))
  (princ)
Henrique
Message 5 of 8
JCprog
it says Unknown command "Tag01=Value01\PTag02=\PTag03=Value03" and it stops and creates only the leader.
Message 6 of 8
hmsilva
in reply to: JCprog
I can't reproduce that behavior, post a sample block...
EDIT: Did the previous mleaders from the previous code worked ok?
Henrique
Message 7 of 8
JCprog
thats weird! now it works perfectly....just one more thing.....
now it list as:
tag01=value01
tag02=value02
tag03=value03
can it just be:
value01
value02
value03
Edit: Disregard the above......This works perfectly!
I modified this line (setq txt (strcat txt (cdr y) "\\P"))
Thanks a million Henrique!Smiley Very Happy
Message 8 of 8
hmsilva
in reply to: JCprog
Change
;; to
EDIT: localize the txt variable, I forgot....
(defun c:demo (/ xrefatts att y lst txt)
Henrique
”Boost
