style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<JSNORTIN> a écrit dans le message de news:is
href="mailto:6051790@discussion.autodesk.com">6051790@discussion.autodesk.com...
there a way to select a block and add a new tag? I have a block called
"address" with the tags "street", "p/s#", "node", "active" i would like to
change these blocks on a dwg by dwg basis to add the tag "zipcode" to the
block.
href="mailto:6052602@discussion.autodesk.com">6052602@discussion.autodesk.com...
couldn't get it to work the block "address" actually is set up with the
attributes like this ADDRESS STREET ACTIVE P/S# NODENAME i missed the one
attribute "ADDRESS" in my original post. I don't know if that affects the lisp
or not but I tried it and it did not work.
<JSNORTIN> a écrit dans le message de news:I'm
href="mailto:6052646@discussion.autodesk.com">6052646@discussion.autodesk.com...
sorry that i didn't mention that the only attribute value visible is the
ADDRESS tag the rest are invisible.i can't get anything to attach to this
message but my email is billj@cable-services.com if you get ahold of me i'll
send you a dwg .
