Hello, I have been brainstorming of ways to make our drawing formats easier to use. And I have a question about if it's possible to link attributes together. For example, I'm making a template for drafting to use for all new drawings. In this drawing I have 10 layout tabs set up and all have the proper drawing format attached to it, and I have attribute blocks set up to make filling out information easier. And in many cases the information (i.e. drawing number, scale and project code) is the same on all sheets. So, is it possible to have the first attribute be the main one and have all the others reference it so you don't have to fill out the same info over and over?
