Attribute moving when inserting dynamic block through macro
16 REPLIES 16
Message 1 of 17
ryled
674 Views, 16 Replies
I am attempting to insert a block that contains two attributes.  I would like to create a button for it, so I have made a macro but whenever I run this macro my top attribute shifts and relates itself to the origin of the UCS.  The odd thing is that the bottom attribute does not, and this only happens when I insert this block through a macro.  If I insert it through the insert command it comes out okay, but that is only if I did not try the macro already in the drawing.  Quite odd.
The macro I used is:
C^C^C-LAYER;SET;"ELEVATION";;^C^C^C-INSERT;"ELEVATION - MODEL";\
I have also tried:
C^C^C-LAYER;SET;"ELEVATION";;^C^C^C-INSERT;"ELEVATION - MODEL";scale;1;rotate;0;
I have attempted to recreate the top attribute in model space, and in block editor.  Copy/Mirror the bottom attribute in model space and block editor and redefine the values to what I want.  I have also tried setting the UCSICON to noorigin and off in the block editor.
If anyone has any suggestions that would be great! Thank you!
I have attached the file below.
16 REPLIES 16
Message 2 of 17
bhull1985
in reply to: ryled
There is an attribute mode called "locked"
Can you lock these attributes in place, for all of your blocks?
I would think that to be the quickest/easiest solution...
Please use code tags and credit where credit is due. Accept as solution, if solved. Let's keep it trim people!
Message 3 of 17
ryled
in reply to: bhull1985
I have both top and bottom attributes lock position set to yes, which is why I believe it works when using the "insert" command, but I would think it would be the same for the "-insert" command but that doesn't seem to be the case.
Message 4 of 17
ryled
in reply to: ryled
If this would be better suited in another section could someone point me in the right direction? I dont want to make multiple threads on the same topic.
Message 5 of 17
hmsilva
in reply to: ryled
Hi ryled,
"whenever I run this macro my top attribute shifts and relates itself to the origin of the UCS"
I can't reproduce that behavior, using
^C^C-LAYER;SET;"ELEVATION";;-INSERT;"ELEVATION - MODEL";\
or
^C^C-LAYER;SET;"ELEVATION";;-INSERT;"ELEVATION - MODEL";scale;1;rotate;0;
at AutoCAD 2010 and 2014...
Henrique
Message 6 of 17
ryled
in reply to: hmsilva
hmsilva,
Are you able to insert the block at all?  I have attached a second block with the same problem.  One of the annotative attributes shifts when it is inserted through a macro but the other one stays in place.  If you insert it through the ribbon, either block, the attributes appear in the correct position.  However if I used a macro, or just run it through the command line with "-Insert" one of the attributes shifts and relates its position to the origin.  Perhaps this would be better suited in the dynamic blocks forum, but I thought it was possibly something incorrect I had done in my macro.
Running AutoCAD 2012 here for the record.
Message 7 of 17
hmsilva
in reply to: ryled
Yes.
Tested in Autocad 2012
Is this expected outcome, correct?
Henrique
Message 8 of 17
ryled
The result you had gotten  I get when I either A) Insert through the ribbon, or B) insert by typing "Insert" through the command line.  That is what I'm looking for.
However I wish to make buttons for these two blocks.  Therefore I need a macro, and with my macros, or through typing "-Insert" into the command line I come out with the placement above.  Notice that in each block one of the annotative attributes places correctly, and one moves to a point relative to the origin.
I am unsure as to why.
Message 9 of 17
hmsilva
in reply to: ryled
As I said before, I can't reproduce that behavior, using
or
^C^C-LAYER;SET;"ELEVATION";;-INSERT;"STATION - MODEL";scale;1;rotate;0;
Just for testing purpose, try
^C^C_.-LAYER;SET;"ELEVATION";;_.-INSERT;"ELEVATION - MODEL";scale;1;rotate;0;
Henrique
Message 10 of 17
ryled
When you do use those macros do you achieve what you had shown in your picture?
I tried using that macro you had shown me for the two commands.
[ELE]^C^C_.-LAYER;SET;"ELEVATION";;_.-INSERT;"ELEVATION - MODEL";SCALE;1;ROTATE;0;
[STATI]^C^C_.-LAYER;SET;"STATION";;_.-INSERT;"STATION - MODEL";SCALE;1;ROTATE;0;
However I get the same  result shown below.
Message 11 of 17
hmsilva
in reply to: ryled
Yes, the picture i had shown was made from blocks inserted with those macros, I did try in AutoCAD 2010/12/14, and always successfully.
I can't understand what is causing that behavior...
Hopefully, someone else can reproduce that behavior.
Henrique
Message 12 of 17
ryled
Maybe I have a system variable set different from what you do?  I'll look into that.  Thanks for your help Henrique, I appreciate it!
Message 13 of 17
hmsilva
in reply to: ryled
You're welcome, ryled.
Unfortunately, I couldn't give you much help...
Henrique
Message 14 of 17
bhull1985
Try using
(command "-insert" ..........)
for your macro, i.e. a lisp driven macro rather than the python or whatever std macros are.
Assuming you're using a full version of cad this should work just as well, being as you're having issues- perhaps even better.
Message 15 of 17
ryled
bhull1985
For my macro I did use "-insert" (see below).  Unless you are referring to something else?
Message 16 of 17
ryled
in reply to: ryled
I found a solution by adding an ATTSYNC to the end of the macro.
[ELEVATION MARKER]^C^C^C-LAYER;SET;"ELEVATION";;^C^C^C-INSERT;"ELEVATION - MODEL";scale;1;rotate;0;\;;^C^C^CATTSYNC;NAME;"ELEVATION - MODEL";
Same concept for the station.
Message 17 of 17
hmsilva
in reply to: ryled
Glad you got a solution!
Henrique
”Boost
