when i insert a block w attributes using toolpalettes , even if attdia set to 0 , i still get the attributes dialog .
anyway to disable it and make attributes display defaults ?
Solved by pbejse. Go to Solution.
I was wondering the same thing. But the Trouble with changing your "ATTREQ" is that now I don't get a command window and I don't get a text prompt in my command line now if I change that to "0". And my "ATTDIA" is set to "0".
