Hello, I need some help.
We have hundreds of drawings where the layouts is in diffrent files then the model, example:
model_E6XX.X
layout_E6XX.X
Is it possible to create a lisp file that i can run that gets the name of the layout file removes "layout" attaches "model" then loads that file so i can run in on multiple files at once?
@Raksos87 wrote:Hello, I need some help.
I think its doable, it requires complex coding to make if foolproof though. but then again. maybe not 🙂
EDIT: The drawing entities are on Layout tabs and you want them transfered to model? does that sound about right? Makes me wonder why there are entities other than the titleblock on paperspace...
Post a sample file Raksos87
It won't be too hard if there is only one viewport in each layout file.
One method is
1. Open the layout file
2. Use CHSPACE to move all entities in layout to model space, and
3. Bind the xref in model space
@3wood wrote:It won't be too hard if there is only one viewport in each layout file.
One method is
That would have been too easy eh 3wood? 🙂 I'm wondering how may layouts does the OP have or viewports per layoyut. problem i see with chspace is, if two or more viewports is showing the same objects in model space but only of different scale, then objects transfered from layout will be on top of the one another, objects like annotations ,title blocks and what not. I guess it will all depend on how the OP's drawing is setup.
Anyhow, happy weekend 🙂
Sorry, I will try to explain myself better. I work with electrical drawings in buildings. The name of my model drawings is model_E6XX.X. For plotting i store all of my layouts in a seperate drawing called layout_E6XX.X. What i want to do is run a script on the drawing "layout_E6XX.X" that attaches the modelfile, where i dont have to change name and stuff.
Does that make more sense?
